I want to get output-meta data from the object_dectector_SSD example and implement an sgie that does some operations on the objects detected by the pgie. I there an example implementation I could refer to for extracting the meta data from the SSD implementation.
PS: I’m using two rtsp streams as an input
We have some sample to deal with metadata information.
Would you mind to check if these samples can meet your requirement first?
/opt/nvidia/deepstream/deepstream-4.0/sources/apps/sample_apps/deepstream-gst-metadata-test
/opt/nvidia/deepstream/deepstream-4.0/sources/apps/sample_apps/deepstream-infer-tensor-meta-test
/opt/nvidia/deepstream/deepstream-4.0/sources/apps/sample_apps/deepstream-user-metadata-test
Sure! I’ll look into them and get back to you if needed.
