Extremely long delay to affect a variable stored into global memory
I am new to CUDA programming (using 3.2 SDK on Linux 32 bits) and I’m having some troubles with a raytracing application in the following kernel:
__constant__ t_obj      current_obj;
__global__void inter_sphere(cu_view *view, unsigned int *color, float *best_dist)
  const int     id = blockIdx.x * blockDim.x + threadIdx.x;
  float         dist;
  cu_view       tmp_v;
tmp_v.posx = view[id].posx - current_obj.posx;
  tmp_v.posy = view[id].posy - current_obj.posy;
  tmp_v.posz = view[id].posz - current_obj.posz;
  tmp_v.vx = view[id].vx;
  tmp_v.vy = view[id].vy;
  tmp_v.vz = view[id].vz;
  cal_dist_poly(&tmp_v, current_obj.rayon, &dist);
  if (__saturatef(dist) && (dist < best_dist[id] || __saturatef(best_dist[id]) == 0))
      best_dist[id] = dist;
      color[id] = (current_obj.r << 16) + (current_obj.g << 8) + current_obj.b;
The two lines inside the if statement under cal_dist_poly() seems to be responsible for 99% of the running time of my kernel. If I comment them, the running time goes from 12 secs down to half a second.
I am calling this kernel with some 1 000 000 threads multiple times, view, color and best_dist are stored into global memory.
nThreads = 256;
  nBlocks = (param->winx * param->winy) / nThreads;
while (tmp)
      CUDA_SAFE_CALL(cudaMemcpyToSymbol(current_obj, tmp, sizeof(cu_obj)));
      if (tmp->type == SPHERE)
        inter_sphere<<<nBlocks, nThreads>>>(view, d_color, d_dist);
      cudaThreadSynchronize();
      tmp = tmp->next;
Am I doing something wrong?
When you comment the lines out, the kernel contains no memory writes, so the compiler optimizes the whole kernel away. The time difference you are seeing is, therefore, the difference between a “null” kernel and your actual code, not the cost of a global memory write.
I see. But then, do you know why the following is almost instantaneous…
  //if (__saturatef(dist) && (dist < best_dist[id] || __saturatef(best_dist[id]) == 0))
  //best_dist[id] = dist;
… and not the following?
  //color[id] = (current_obj.r << 16) + (current_obj.g << 8) + current_obj.b;
Either way, my kernel is now writing into global memory, isn’t it?
cal_dist_poly() just does some computations and store the result into dist.
nvcc inlines all device function calls before doing dead code optimization. If dist does not ultimately affect a result written to memory, the compiler might remove all of cal_dist_poly from the kernel.
