Hello everyone !
This post is a copy of my post here : F32 : upgrade to 32.20200905.0 from 32.20200822.0 nvidia troubles - Fedora Discussion
I tried to upgrade my system two days ago and I have a strange problem maybe with nvidia driver ?
On the 32.20200913.0, one of my two screens leave blank, OBS says there is a problem with my GPU and Blender doesn’t detect CUDA ( the last one is because for some reasons the upgrade remove the xorg-x11-drv-nvidia-cuda-libs, so I reinstall by hand ) It’s ok now since this version !
On the 32.20200822.0, no of these problems appear.
I suspect a problem with the last nvidia driver version 450.66, but nothing seems wrong in my logs !
There is the same rpm-ostree kargs
output ( except ostree as expected ) between the two version : resume=/dev/mapper/fedora-swap rd.lvm.lv=fedora/root rd.lvm.lv=fedora/swap rhgb quiet root=/dev/mapper/fedora-root ostree=/ostree/boot.1/fedora/f34b26550c169909ad3b35a00282ac8747a97b66095956df211e97062b1caa80/0 rd.driver.blacklist=nouveau nvidia-drm.modeset=1
Same lsmod, services, unit files and Xorg logs, and no other error in logs…
Gnome detect the two screens because windows pop up in my blank screen.
Nvidia-settings seems ok too, it detect the two screen, etc… But always a blank screen.
My config :
- CPU : AMD RYZEN 9 3950X
- GPU : NVIDIA 2080 TI ( MSI )
- Memory : 32Go Corsair LPX Vengeance
Packages installed for nvidia : akmod-nvidia, xorg-x11-drv-nvidia xorg-x11-drv-nvidia-cuda-lib, xorg-x11-drv-nvidia-libs, xorg-x11-drv-nvidia-libs.i686
I’m an experimented GNU/linux user but now I don’t what happened here…
