f90main.o error with undefined main under linux
I try to call a C function without using the underscore in a Fortran program, but I got a error regarding a undefined main.
I would like to know if I don’t miss any compilation switches.
Here the example, I try to compile:
foo.c:
#include <stdio.h>
void cprint(char* string){
printf("%s", string);
main.f90:
program main
implicit none
call cprint(" Hello world!\n"// char(0))
end program main
% gcc -g -c foo.c
% pgf90 -Mnounderscoring -g -c main.f90
% pgf90 -pgf90libs -g -o bar.out main.o foo.o
/opt/pgi/linux86/6.2/lib/f90main.o(.text+0x77): In function main': : undefined reference to MAIN_’
Regards,
Maxime
Hi Maxime,
The most portable solution to the Fortran to C underscoring problem is to write a Fortran interface wrapper function. While a little extra coding, it will save you countless headaches in the future.
For example, you can add the following:
% cat foo.c
#include <stdio.h>
#ifdef DOUBLE_UNDERSCORE
#define FFUNC(X, Y) X##__ (Y var) { X(var); }
#define FFUNC2(X, Y, Z) X##__ (Y var, Z var2) { X(var, var2); }
#else
#define FFUNC(X, Y) X##_ (Y var) { X(var); }
#define FFUNC2(X, Y, Z) X##_ (Y var, Z var2) { X(var, var2); }
#endif
void FFUNC(cprint, char*)
% gcc -g -c foo.c
% pgf90 -V6.2-4 -g -c main.f90
% pgf90 -V6.2-4 -o bar.out main.o foo.o
% bar.out
 Hello world!
Hope this helps,
Mat
It’s working great!
Thank you for your time, Mat.
