F95 compiler bug?
I put a test program up at
http://frank.harvard.edu/~coldwell/pgitest.tar.gz
I believe the code is correct, but the binary generated by pgf95 segfaults. I’ve also tried it with the compilers from Sun, Intel, DEC/Compaq/HP (Alpha), and GNU. The binaries generated by these other compilers run correctly.
This is with the latest version of the PGI compilers.
Can anyone see a bug in my code?
Chip
Hi Chip,
Thank you for the report and the nice test code. I have verfied that the pgf901 seg fault has been fixed in the 6.2-5 release (currently scheduled for release Nov. 2nd, 2006). However, it appears that there are other compiler issues so I have created a technical problem report (TPR#3990) and have passed this on to our Engineering team.
Hopefully we can address these issues shortly.
Thanks,
Mat
Thanks a million for the quick reply.
Chip
