Hello fellows,
I encountered the following issues, when:
sudo apt upgrade
Reading package lists... Done Building dependency tree... Done Reading state information... Done You might want to run 'apt --fix-broken install' to correct these. The following packages have unmet dependencies: cuda-drivers-fabricmanager-515 : Depends: nvidia-fabricmanager-515 (= 515.86.01-0ubuntu0.22.04.1) but it is not installed nvidia-fabricmanager-510 : Depends: nvidia-fabricmanager-515 but it is not installed E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
After trying the proposed solution
sudo apt --fix-broken install
Reading package lists... Done Building dependency tree... Done Reading state information... Done Correcting dependencies... Done The following packages were automatically installed and are no longer required: libflashrom1 libftdi1-2 nvidia-fabricmanager-510 Use 'sudo apt autoremove' to remove them. The following additional packages will be installed: nvidia-fabricmanager-515 The following NEW packages will be installed: nvidia-fabricmanager-515 0 upgraded, 1 newly installed, 0 to remove and 53 not upgraded. 3 not fully installed or removed. Need to get 0 B/1.568 kB of archives. After this operation, 8.005 kB of additional disk space will be used. Do you want to continue? [Y/n] y (Reading database ... 298175 files and directories currently installed.) Preparing to unpack .../nvidia-fabricmanager-515_515.86.01-0ubuntu0.22.04.1_amd64.deb ... Unpacking nvidia-fabricmanager-515 (515.86.01-0ubuntu0.22.04.1) ... dpkg: error processing archive /var/cache/apt/archives/nvidia-fabricmanager-515_515.86.01-0ubuntu0.22.04.1_amd64.deb (--unpack): trying to overwrite '/lib/systemd/system/nvidia-fabricmanager.service', which is also in package nvidia-fabricmanager-510 515.86.01-0ubuntu0.22.04.1 dpkg-deb: error: paste subprocess was killed by signal (Broken pipe) Errors were encountered while processing: /var/cache/apt/archives/nvidia-fabricmanager-515_515.86.01-0ubuntu0.22.04.1_amd64.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
I could not do a reinstallation by removing nvidia via apt.
Hopefully you can help me with this issue.
I do not have any visible problems yet, but Ubuntu package manager also shows, that an error occurred and need to be solved manually.
My system specs:
HW
Lenovo Lenovo IdeaPad C340-15IWL
20 GiB
Intel® Core™ i7-8565U CPU @ 1.80GHz × 8
NVIDIA Corporation GP108M [GeForce MX230] / NVIDIA GeForce MX230/PCIe/SSE2
SW
Ubuntu 22.04.1 LTS
64-bit
Gnome 42.5
Windowing System X11
And
dpkg -l | grep nvidia
ii libnvidia-cfg1-510:amd64 510.85.02-0ubuntu0.22.04.2 amd64 NVIDIA binary OpenGL/GLX configuration library ii libnvidia-common-510 510.85.02-0ubuntu0.22.04.2 all Shared files used by the NVIDIA libraries ii libnvidia-compute-495:amd64 510.85.02-0ubuntu0.22.04.2 amd64 Transitional package for libnvidia-compute-510 ii libnvidia-compute-510:amd64 510.85.02-0ubuntu0.22.04.2 amd64 NVIDIA libcompute package ii libnvidia-compute-510:i386 510.85.02-0ubuntu0.22.04.2 i386 NVIDIA libcompute package ii libnvidia-decode-510:amd64 510.85.02-0ubuntu0.22.04.2 amd64 NVIDIA Video Decoding runtime libraries ii libnvidia-decode-510:i386 510.85.02-0ubuntu0.22.04.2 i386 NVIDIA Video Decoding runtime libraries ii libnvidia-egl-wayland1:amd64 1:1.1.9-1.1 amd64 Wayland EGL External Platform library -- shared library ii libnvidia-encode-510:amd64 510.85.02-0ubuntu0.22.04.2 amd64 NVENC Video Encoding runtime library ii libnvidia-encode-510:i386 510.85.02-0ubuntu0.22.04.2 i386 NVENC Video Encoding runtime library ii libnvidia-extra-510:amd64 510.85.02-0ubuntu0.22.04.2 amd64 Extra libraries for the NVIDIA driver ii libnvidia-fbc1-510:amd64 510.85.02-0ubuntu0.22.04.2 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library ii libnvidia-fbc1-510:i386 510.85.02-0ubuntu0.22.04.2 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library ii libnvidia-gl-510:amd64 510.85.02-0ubuntu0.22.04.2 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD ii libnvidia-gl-510:i386 510.85.02-0ubuntu0.22.04.2 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD ii libnvidia-ml-dev:amd64 11.5.50~11.5.1-1ubuntu1 amd64 NVIDIA Management Library (NVML) development files rc linux-modules-nvidia-510-5.15.0-25-generic 5.15.0-25.25 amd64 Linux kernel nvidia modules for version 5.15.0-25 rc linux-modules-nvidia-510-5.15.0-27-generic 5.15.0-27.28 amd64 Linux kernel nvidia modules for version 5.15.0-27 rc linux-modules-nvidia-510-5.15.0-33-generic 5.15.0-33.34 amd64 Linux kernel nvidia modules for version 5.15.0-33 rc linux-modules-nvidia-510-5.15.0-35-generic 5.15.0-35.36+1 amd64 Linux kernel nvidia modules for version 5.15.0-35 rc linux-modules-nvidia-510-5.15.0-37-generic 5.15.0-37.39 amd64 Linux kernel nvidia modules for version 5.15.0-37 rc linux-modules-nvidia-510-5.15.0-39-generic 5.15.0-39.42 amd64 Linux kernel nvidia modules for version 5.15.0-39 rc linux-modules-nvidia-510-5.15.0-40-generic 5.15.0-40.43+1 amd64 Linux kernel nvidia modules for version 5.15.0-40 rc linux-modules-nvidia-510-5.15.0-41-generic 5.15.0-41.44+1 amd64 Linux kernel nvidia modules for version 5.15.0-41 rc linux-modules-nvidia-510-5.15.0-43-generic 5.15.0-43.46+1 amd64 Linux kernel nvidia modules for version 5.15.0-43 rc linux-modules-nvidia-510-5.15.0-48-generic 5.15.0-48.54 amd64 Linux kernel nvidia modules for version 5.15.0-48 rc linux-modules-nvidia-510-5.15.0-50-generic 5.15.0-50.56+1 amd64 Linux kernel nvidia modules for version 5.15.0-50 ii linux-modules-nvidia-510-5.15.0-52-generic 5.15.0-52.58+1 amd64 Linux kernel nvidia modules for version 5.15.0-52 ii linux-modules-nvidia-510-5.15.0-53-generic 5.15.0-53.59+1 amd64 Linux kernel nvidia modules for version 5.15.0-53 ii linux-modules-nvidia-510-generic-hwe-22.04 5.15.0-53.59+1 amd64 Extra drivers for nvidia-510 for the generic-hwe-22.04 flavour rc linux-objects-nvidia-510-5.15.0-25-generic 5.15.0-25.25 amd64 Linux kernel nvidia modules for version 5.15.0-25 (objects) rc linux-objects-nvidia-510-5.15.0-27-generic 5.15.0-27.28 amd64 Linux kernel nvidia modules for version 5.15.0-27 (objects) rc linux-objects-nvidia-510-5.15.0-33-generic 5.15.0-33.34 amd64 Linux kernel nvidia modules for version 5.15.0-33 (objects) rc linux-objects-nvidia-510-5.15.0-35-generic 5.15.0-35.36+1 amd64 Linux kernel nvidia modules for version 5.15.0-35 (objects) rc linux-objects-nvidia-510-5.15.0-37-generic 5.15.0-37.39 amd64 Linux kernel nvidia modules for version 5.15.0-37 (objects) rc linux-objects-nvidia-510-5.15.0-39-generic 5.15.0-39.42 amd64 Linux kernel nvidia modules for version 5.15.0-39 (objects) rc linux-objects-nvidia-510-5.15.0-40-generic 5.15.0-40.43+1 amd64 Linux kernel nvidia modules for version 5.15.0-40 (objects) rc linux-objects-nvidia-510-5.15.0-41-generic 5.15.0-41.44+1 amd64 Linux kernel nvidia modules for version 5.15.0-41 (objects) rc linux-objects-nvidia-510-5.15.0-43-generic 5.15.0-43.46+1 amd64 Linux kernel nvidia modules for version 5.15.0-43 (objects) rc linux-objects-nvidia-510-5.15.0-48-generic 5.15.0-48.54 amd64 Linux kernel nvidia modules for version 5.15.0-48 (objects) rc linux-objects-nvidia-510-5.15.0-50-generic 5.15.0-50.56+1 amd64 Linux kernel nvidia modules for version 5.15.0-50 (objects) ii linux-objects-nvidia-510-5.15.0-52-generic 5.15.0-52.58+1 amd64 Linux kernel nvidia modules for version 5.15.0-52 (objects) ii linux-objects-nvidia-510-5.15.0-53-generic 5.15.0-53.59+1 amd64 Linux kernel nvidia modules for version 5.15.0-53 (objects) ii linux-signatures-nvidia-5.15.0-52-generic 5.15.0-52.58+1 amd64 Linux kernel signatures for nvidia modules for version 5.15.0-52-generic ii linux-signatures-nvidia-5.15.0-53-generic 5.15.0-53.59+1 amd64 Linux kernel signatures for nvidia modules for version 5.15.0-53-generic ii nvidia-compute-utils-510 510.85.02-0ubuntu0.22.04.2 amd64 NVIDIA compute utilities ii nvidia-cuda-dev:amd64 11.5.1-1ubuntu1 amd64 NVIDIA CUDA development files ii nvidia-cuda-gdb 11.5.114~11.5.1-1ubuntu1 amd64 NVIDIA CUDA Debugger (GDB) ii nvidia-cuda-toolkit 11.5.1-1ubuntu1 amd64 NVIDIA CUDA development toolkit ii nvidia-cuda-toolkit-doc 11.5.1-1ubuntu1 all NVIDIA CUDA and OpenCL documentation ii nvidia-driver-510 510.85.02-0ubuntu0.22.04.2 amd64 NVIDIA driver metapackage iU nvidia-fabricmanager-510 515.86.01-0ubuntu0.22.04.1 amd64 Transitional package for nvidia-fabricmanager-#FLAVOUR# ii nvidia-kernel-common-510 510.85.02-0ubuntu0.22.04.2 amd64 Shared files used with the kernel module ii nvidia-kernel-source-510 510.85.02-0ubuntu0.22.04.2 amd64 NVIDIA kernel source package ii nvidia-opencl-dev:amd64 11.5.1-1ubuntu1 amd64 NVIDIA OpenCL development files ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA's Prime ii nvidia-profiler 11.5.114~11.5.1-1ubuntu1 amd64 NVIDIA Profiler for CUDA and OpenCL ii nvidia-settings 510.47.03-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver ii nvidia-utils-510 510.85.02-0ubuntu0.22.04.2 amd64 NVIDIA driver support binaries ii nvidia-visual-profiler 11.5.114~11.5.1-1ubuntu1 amd64 NVIDIA Visual Profiler for CUDA and OpenCL ii screen-resolution-extra 0.18.2 all Extension for the nvidia-settings control panel ii xserver-xorg-video-nvidia-510 510.85.02-0ubuntu0.22.04.2 amd64 NVIDIA binary Xorg driver
And of course
dpkg -l | grep cuda
iU cuda-drivers-fabricmanager-510 515.86.01-0ubuntu0.22.04.1 amd64 Transitional package for cuda-drivers-fabricmanager-515 iU cuda-drivers-fabricmanager-515 515.86.01-0ubuntu0.22.04.1 amd64 Meta-package for FM and Driver ii libcudart11.0:amd64 11.5.117~11.5.1-1ubuntu1 amd64 NVIDIA CUDA Runtime Library ii nvidia-cuda-dev:amd64 11.5.1-1ubuntu1 amd64 NVIDIA CUDA development files ii nvidia-cuda-gdb 11.5.114~11.5.1-1ubuntu1 amd64 NVIDIA CUDA Debugger (GDB) ii nvidia-cuda-toolkit 11.5.1-1ubuntu1 amd64 NVIDIA CUDA development toolkit ii nvidia-cuda-toolkit-doc 11.5.1-1ubuntu1 all NVIDIA CUDA and OpenCL documentation
