Face detection with Jetson Nano Jetbot
I just got a Jetson Nano and want to set up a robot with face detection from (https://github.com/JetsonHacksNano/CSI-Camera).
When I access the Jetson directly the face_detect.py works just fine with the code below in the terminal. But the code does not work, when I access it from my deskPC via wifi / from my deskPCs browser and like it is discribed for the Jetbot (Step4 in https://github.com/NVIDIA-AI-IOT/jetbot/wiki/software-setup).
When i try the code in Jupyter lab, just nothin happens. Even though the liberies cv2 and numpy seem to be imported fine.
When I try to open the script from the console with
cd CSI-Camera
and
python face_detect.py
it says (python:14648): Gtk-WARNING **: 09:08:13.993: cannot open display:
Does anybody know how to figure this out?
Kind regards and thanks for any help,
Mat
This is because the sample need a DISPLAY to show the output result.
However, it’s not supported to redirect the window via ssh.
Here are two alternatives for your reference:
1. Use local display for the output.
Try to setup the DISPLAY parameter before the python code.
$ export DISPLAY=:1
$ python face_detect.py
2. Turn off the window output.
Remove or comment the imshow command.
https://github.com/JetsonHacksNano/CSI-Camera/blob/master/face_detect.py#L70
thanks you. But it looks like this didn’t solve my problem.
is the export DISPLAY=:1 supposed to open a new window for displaying the view from the camera? At least in my case no dispaly opens and i get the same error.
When i comment the imshow in the jupyterlab script also nothing happens. Where is the image supposed to display when i comment the imshow command?
Thanks again,
Matt
Sorry for the late update.
Do you have a display device connected to the Jetson platform directly?
Please noticed that you will need one to enable the x-window.
i have no display connected yet. The idea was to display the video stream inline in the juypter lab / notebook.
Is a PiOLED-Display enough, like mentioned here (https://github.com/NVIDIA-AI-IOT/jetbot/wiki/hardware-setup), or do i need a display to display the videostream? I guess the idea behind the PiOLED is to display the IP-Adress.
thanks,
Matt
Sorry that we don’t have too much experience on the PiOLED-Display.
But if the display can work on Jetson, it should also work for your code.
If you don’t have a display right now, you can change the code to save it as an image.
