Faced an error running “deepstream_python_apps/apps/runtime_source_add_delete” (RTSP source)
I’ve been facing an error running deepstream_python_apps/apps/runtime_source_add_delete. The input source is RTSP. I run it without modifying anything, and I get the following error:
Now playing...
1 :  rtsp://yhara:yhara@192.168.21.11:554/stream1
Starting pipeline
Decodebin child added: decodebin0
Decodebin child added: decodebin1
Decodebin child added: rtph264depay0
Decodebin child added: rtppcmadepay0
Decodebin child added: h264parse0
Decodebin child added: alawdec0
In cb_newpad
gstname= audio/x-raw
Decodebin child added: capsfilter0
Decodebin child added: nvv4l2decoder0
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
In cb_newpad
gstname= video/x-raw
sink_0
Decodebin linked to pipeline
reference in DPB was never decoded
NVDEC_COMMON: NvDecGetSurfPinHandle : Surface not registered
Calling Start 3
Creating uridecodebin for [rtsp://yosukehara:harayosuke@192.168.11.30:554/stream1]
source-bin-03
Decodebin child added: source
STATE CHANGE NO PREROLL
Error: gst-resource-error-quark: Could not write to resource. (10): gstrtspsrc.c(7447): gst_rtspsrc_setup_streams_start (): /GstPipeline:pipeline0/GstURIDecodeBin:source-bin-03/GstRTSPSrc:source:
Error (406): Not Acceptable
Exiting app
[NvMultiObjectTracker] De-initialized
• Hardware Platform (Jetson / GPU): Jetson Xavier NX
• DeepStream Version: 6.2
• JetPack Version (valid for Jetson only): 5.1
• TensorRT Version
Command line:
$ python3 deepstream_rt_src_add_del.py rtsp://yhara:yhara@192.168.21.11:554/stream1
I’ve attached the run-time log.
gstlog.txt (15.2 MB)
Thank you for your confirmation.
Best,
Yosuke
It’s a bug.
I can reproduce sometime.
We will look into this issue and will be back once there is any progress.
