FaceLandmarks is slow on Jetson Nano
Hi.
I am using this FaceLandmarks model Facial Landmarks Estimation | NVIDIA NGC . And there is information that it should give around ~115FPS on Jetson Nano with one face but I got only 5-10FPS.
I use this repository for testing: GitHub - NVIDIA-AI-IOT/deepstream_tao_apps: Sample apps to demonstrate how to deploy models trained with TAO on DeepStream
I am running some project with face detection and I got 60FPS with 60FPS real time input and that is awesome but want to add some additional feature. With all standards properties. For example when I remove from pipeline face landmarks element (SGIE) from deepstream_facelandmarks_app.cpp then I see that there is fast face detector working like a charm. What can cause that face landmarks model perform much slower then from ngc documentation?
MAXN mode is on.
Best regards,
Darek
The table is tested by the trtexec tool, which measures the pure inference time.
Would you mind checking the model with trtexec to see if you can get a similar performance first?
Please remember to fix the clock to the maximum with tegrastats and use the fp16 mode for inference.
