Facial Landmark Estimator (FPENet); how to use on 1920x1200 resolutuion
• Hardware : Jetson Orin Nano
• Network Type (Tao Facelandmark FpeNET)
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
My Input from the camera is 1920x1200. I want to use on this use facelandmarks FPEnet and crop eyes seperately without loosing resolution but the max input tensor sgie is = 80x80 and jetson max scaling = x16 therefore x1/16; 80*16=1280 . Is there any way that I can use 1920 resolution?? Appreciate your help, best regards
What do you mean by “jetson max scaling”?
For running fpenet, you can refer to the pipeline in
https://github.com/NVIDIA-AI-IOT/deepstream_tao_apps/tree/master/apps/tao_others/deepstream-faciallandmark-app and config in https://github.com/NVIDIA-AI-IOT/deepstream_tao_apps/tree/master/configs/nvinfer/facial_tao. The 1920x1200 should be working.
Thanks for your reply. If the PGIE forwards a picture bigger than 1280 size, we receive this error:
/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform.cpp:4575: => VIC Configuration failed image scale factor exceeds 16, use GPU for Transformation
We needed 24 on jetson orin. any suggestions?
Could you try to refer to the solution mentioned in DeepStream SDK FAQ - #29 by fanzh ?
I need to scale more than 16. I will try scaling-compute-hw=1 .
Would rescaling the pgie obj_meta rect_params distort the results in shie?
Any other suggestions?
According to DeepStream SDK FAQ - #29 by fanzh, can you add below into https://github.com/NVIDIA-AI-IOT/deepstream_tao_apps/blob/master/configs/nvinfer/facial_tao/config_infer_primary_facenet.txt and retry?
input-object-min-height=26
input-object-min-width=46
1920x1200 input -->PGIE(facedetect)–>SGIE(facelandmark)
PGIE(facedetect):
infer-dims=3;736;416
This does not help as the scaling is not there; I do not receive small faces so that PGIE has to find more than 16 times smaller faces. I had scaling problem at SGIE, where the frame was more than16x bigger than infer-dim of SGIE. I can limit in opposite input-object-max-height or not use VIC and use GPU. I hope this does not bring to much work for GPU, for that I have to profile. At the Facelandmark example, it has virtually no effect, both have about 57 FPS. I appreciate your helps, thanks, it is solved now
