Faciallandmark model only works when there is only one face in the image.d
Deepstream 6.4 dGPU
I have a pipeline wherein I’m using FacialLandmarks Estimation model from Tao and I referred to this sample.
My config files are :-
gpu-id=0
model-engine-file=model.etlt_b32_gpu0_int8.engine
tlt-model-key=nvidia_tlt
tlt-encoded-model=model.etlt
int8-calib-file=int8_calibration.txt
#dynamic batch size
batch-size=32
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-detected-classes=1
output-blob-names=softargmax;softargmax:1;conv_keypoints_m80
#0=Detection 1=Classifier 2=Segmentation 100=other
network-type=100
# Enable tensor metadata output
output-tensor-meta=1
#1-Primary  2-Secondary
process-mode=2
operate-on-gie-id=1
net-scale-factor=1.0
offsets=0.0
classifier-async-mode=0
input-object-min-width=5
input-object-min-height=5
#0=RGB 1=BGR 2=GRAY
model-color-format=2
gie-unique-id=2
[class-attrs-all]
threshold=0.0
and
maxBatchSize=32
inputLayerWidth=80
inputLayerHeight=80
The problem that I am facing is that, the landmark estimation is working properly only when there is one face in the image.
if there are multiple faces, them landmarks estimation is random for all except one face.
I have copied this entire post from one of my earlier post which got closed due to inactivity.
like to previous post :- link to previous post
• DeepStream Version
• TensorRT Version
We did not reproduce the issue you reported. What can we do for you?
Hardware Platform (Jetson / GPU) :- dGPU
DeepStream Version :- 6.4
TensorRT Version :- probably 8.6
NVIDIA GPU Driver Version :- 535
How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) :- run the faciallandmarks sample app on a video that has more than one person. or maybe try it out on the video that I provide you, if the issues is not getting reproduced on the video that you use.
Please provide the video you used.
