Facing an Issue while using LPR app
Deepstream app failed while building engine file for sgie2 : us_lprnet_baseline18_deployable.etlt
0:00:01.256299095 30248 0x3a1bca0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 3]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps/deepstream_lpr_app/models/LP/LPR/us_lprnet_baseline18_deployable.etlt_b16_gpu0_fp16.engine failed
0:00:01.256360773 30248 0x3a1bca0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 3]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps/deepstream_lpr_app/models/LP/LPR/us_lprnet_baseline18_deployable.etlt_b16_gpu0_fp16.engine failed, try rebuild
0:00:01.256391192 30248 0x3a1bca0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 3]: Trying to create engine from model files
WARNING: [TRT]: onnx2trt_utils.cpp:364: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
WARNING: [TRT]: ShapedWeights.cpp:173: Weights td_dense/kernel:0 has been transposed with permutation of (1, 0)! If you plan on overwriting the weights with the Refitter API, the new weights must be pre-transposed.
WARNING: [TRT]: Tensor DataType is determined at build time for tensors not marked as input or output.
WARNING: [TRT]: Detected invalid timing cache, setup a local cache instead
python3: /dvs/p4/build/sw/rel/gpgpu/MachineLearning/myelin_trt8/src/compiler/optimizer/cublas_impl.cpp:477: void add_heuristic_results_to_tactics(std::vector<cublasLtMatmulHeuristicResult_t>&, std::vectormyelin::ir::tactic_attribute_t&, myelin::ir::tactic_attribute_t&, bool): Assertion `false && "Invalid size written"' failed.
Aborted (core dumped)
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
root@c79ec6aed68e:/opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps/apps/deepstream-lpr-pyt
hon-version# python3 deepstream_lpr_app.py 1 2 0 file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.mp4 output.mp4
['deepstream_lpr_app.py', '1', '2', '0', 'file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.mp4', 'output.mp4']
1
Creating Pipeline
Creating streamux
Creating source_bin 0
file://file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.mp4
Creating source bin
source-bin-00
Creating Pgie
Creating tiler
Creating nvdsanalytics
Creating nvvidconv1
Creating filter1
Creating tiler
Creating nvvidconv
Creating nvosd
Creating FakeSink
Warning: 'input-dims' parameter has been deprecated. Use 'infer-dims' instead.
Adding elements to Pipeline
Linking elements in the Pipeline
Now playing...
4 : file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.mp4
Starting pipeline
0:00:00.802258261 17048 0x362f8a0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 3]: Trying to create engine from model files
python3: /dvs/p4/build/sw/rel/gpgpu/MachineLearning/myelin_trt8/src/compiler/optimizer/cublas_impl.cpp:477: void add_heuristic_results_to_tactics(std::vector<cublasLtMatmulHeuristicResult_t>&, std::vector<myelin::ir::tactic_attribute_t>&, myelin::ir::tactic_attribute_t&, bool): Assertion `false && "Invalid size written"' failed.
