I have cuda kernel that does something like below
__device int func(const float4 vec)
float4 test = -vec;
This gave me compilation error about no operator - takes argument const float4 so I overloaded operator - like below
inline __device__ float4 operator-(const float4 a) {return make_float4(-a.x,-a.y,-a.z,-a.w);}
That fixed the error but now I am getting some more errors.
I have code like below
__device int func()
float4 test = ...;
test = -test;
Now I am getting following errors
error: more than one operator "-" matches these operands:
function "operator-(float4 &)"
function "operator-(float4)"
operand types are: - float4
any one know how I can fix this ?
After fixing some typos, I don’t have any trouble with what you have shown:
$ cat t30.cu
__device__ void func1(const float4 vec)
float4 test = -vec;
__device__ void func2(const float4 vec)
float4 test = vec;
test = -test;
$ nvcc -c t30.cu
My guess would be that you actually have something like this:
$ cat t30.cu
inline __device__ float4 operator-(const float4 &a) {return make_float4(-a.x,-a.y,-a.z,-a.w);}
float4 test = -vec;
float4 test = vec;
test = -test;
$ nvcc -c t30.cu
t30.cu(6): error: more than one operator "-" matches these operands:
function "operator-(const float4 &)"
operand types are: - const float4
t30.cu(12): error: more than one operator "-" matches these operands:
2 errors detected in the compilation of "t30.cu".
In which case I would say “don’t do that.” Get rid of the operator overload that passes its argument by value, and just use the pass-by-reference version.
By the way I doubt this problem has anything to do with CUDA:
$ cat t30.cpp
#define __device__
#include "/usr/local/cuda/include/vector_types.h"
#include "/usr/local/cuda/include/vector_functions.h"
float4 test = -vec;
float4 test = vec;
test = -test;
$ g++ -c t30.cpp
t30.cpp: In function ‘void func1(float4)’:
t30.cpp:9:18: error: ambiguous overload for ‘operator-’ (operand type is ‘const float4’)
float4 test = -vec;
t30.cpp:4:26: note: candidate: float4 operator-(float4)
t30.cpp:5:26: note: candidate: float4 operator-(const float4&)
t30.cpp: In function ‘void func2(float4)’:
t30.cpp:15:11: error: ambiguous overload for ‘operator-’ (operand type is ‘float4’)
test = -test;
I did not have
but I had only one as I showed in code snippet.
But I replaced above function with
inline __device__ float4 operator-(const float4& a) {return make_float4(-a.x,-a.y,-a.z,-a.w);}
That fixed my issue.
The other one was around, somewhere. Your error output makes that evident, and I’ve already demonstrated that your code snippet, by itself, does not generate the error you are showing. If you still disagree, my suggestion would be to provide a complete example that I can compile and see the error output you are suggesting.
