### setuptools version
setuptools>=71.0.0
### Python version
Python 3.12
###… OS
Ubuntu
### Additional environment information
I found this bug when running the test for the project in GitHub actions
### Description
When I install the requirements in my Python package project (`pip-sync requirements-dev.txt`) I get an error within setuptools which says:
Preparing metadata (setup.py) ... error
error: subprocess-exited-with-error
× python setup.py egg_info did not run successfully.
TypeError: canonicalize_version() got an unexpected keyword argument 'strip_trailing_zero'
This error was caused by using setuptools >= 71.0.0
Not to speculate but it looks like the issue was introduced by this commit in setuptools: https://github.com/pypa/setuptools/commit/00384a5f4fd22c653172b99feefe13b0009eb870
And this commit is including new changes from the packaging project and its this commit here where we can see the issue:
https://github.com/pypa/packaging/commit/cc938f984bbbe43c5734b9656c9837ab3a28191f
https://github.com/pypa/packaging/blame/4493dfcd95a893f676a7aa4bd17c547bea676371/src/packaging/utils.py#L58
### Expected behavior
I would expect `pip-sync requirements-dev.txt` to run successfully
### How to Reproduce
Clone https://github.com/tim-s-ccs/example-python-package.git
Make sure you are using Python 3.12 and you have pip-tools installed (`pip install --upgrade pip wheel pip-tools`)
Make sure you are using the correct version of setuptools `pip install --upgrade setuptools==71.0.0`
Run `pip-compile requirements-dev.in`
### Output
```console
│ exit code: 1
╰─> [42 lines of output]
running egg_info
creating /private/var/folders/kt/n16_msf56_z3kfyb65l37wxhb_m4s_/T/pip-pip-egg-info-3sca_19y/example_python_package.egg-info
writing /private/var/folders/kt/n16_msf56_z3kfyb65l37wxhb_m4s_/T/pip-pip-egg-info-3sca_19y/example_python_package.egg-info/PKG-INFO
writing dependency_links to /private/var/folders/kt/n16_msf56_z3kfyb65l37wxhb_m4s_/T/pip-pip-egg-info-3sca_19y/example_python_package.egg-info/dependency_links.txt
writing top-level names to /private/var/folders/kt/n16_msf56_z3kfyb65l37wxhb_m4s_/T/pip-pip-egg-info-3sca_19y/example_python_package.egg-info/top_level.txt
writing manifest file '/private/var/folders/kt/n16_msf56_z3kfyb65l37wxhb_m4s_/T/pip-pip-egg-info-3sca_19y/example_python_package.egg-info/SOURCES.txt'
reading manifest file '/private/var/folders/kt/n16_msf56_z3kfyb65l37wxhb_m4s_/T/pip-pip-egg-info-3sca_19y/example_python_package.egg-info/SOURCES.txt'
File "<string>", line 2, in <module>
File "<pip-setuptools-caller>", line 34, in <module>
File "/Users/my.name/Code/test/example-python-package/setup.py", line 16, in <module>
setup(
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/setuptools/__init__.py", line 106, in setup
return distutils.core.setup(**attrs)
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/setuptools/_distutils/core.py", line 184, in setup
return run_commands(dist)
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/setuptools/_distutils/core.py", line 200, in run_commands
dist.run_commands()
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/setuptools/_distutils/dist.py", line 970, in run_commands
self.run_command(cmd)
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/setuptools/dist.py", line 974, in run_command
super().run_command(command)
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/setuptools/_distutils/dist.py", line 989, in run_command
cmd_obj.run()
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/setuptools/command/egg_info.py", line 321, in run
self.find_sources()
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/setuptools/command/egg_info.py", line 329, in find_sources
mm.run()
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/setuptools/command/egg_info.py", line 555, in run
self.prune_file_list()
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/setuptools/command/egg_info.py", line 621, in prune_file_list
base_dir = self.distribution.get_fullname()
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/setuptools/_core_metadata.py", line 266, in get_fullname
return _distribution_fullname(self.get_name(), self.get_version())
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/setuptools/_core_metadata.py", line 284, in _distribution_fullname
canonicalize_version(version, strip_trailing_zero=False),
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/pip/_internal/operations/build/metadata_legacy.py", line 64, in generate_metadata
call_subprocess(
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/pip/_internal/utils/subprocess.py", line 209, in call_subprocess
raise error
pip._internal.exceptions.InstallationSubprocessError: python setup.py egg_info exited with 1
The above exception was the direct cause of the following exception:
File "/Users/my.name/.pyenv/versions/3.12.2/bin/pip-compile", line 8, in <module>
sys.exit(cli())
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/click/core.py", line 1157, in __call__
return self.main(*args, **kwargs)
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/click/core.py", line 1078, in main
rv = self.invoke(ctx)
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/click/core.py", line 1434, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/click/core.py", line 783, in invoke
return __callback(*args, **kwargs)
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/click/decorators.py", line 33, in new_func
return f(get_current_context(), *args, **kwargs)
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/piptools/scripts/compile.py", line 470, in cli
results = resolver.resolve(max_rounds=max_rounds)
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/piptools/resolver.py", line 604, in resolve
is_resolved = self._do_resolve(
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/piptools/resolver.py", line 636, in _do_resolve
resolver.resolve(
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/pip/_internal/resolution/resolvelib/resolver.py", line 76, in resolve
collected = self.factory.collect_root_requirements(root_reqs)
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/pip/_internal/resolution/resolvelib/factory.py", line 538, in collect_root_requirements
reqs = list(
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/pip/_internal/resolution/resolvelib/factory.py", line 494, in _make_requirements_from_install_req
cand = self._make_base_candidate_from_link(
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/pip/_internal/resolution/resolvelib/factory.py", line 210, in _make_base_candidate_from_link
self._editable_candidate_cache[link] = EditableCandidate(
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 328, in __init__
super().__init__(
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 158, in __init__
self.dist = self._prepare()
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 235, in _prepare
dist = self._prepare_distribution()
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 338, in _prepare_distribution
return self._factory.preparer.prepare_editable_requirement(self._ireq)
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/pip/_internal/operations/prepare.py", line 698, in prepare_editable_requirement
dist = _get_prepared_distribution(
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/pip/_internal/operations/prepare.py", line 72, in _get_prepared_distribution
abstract_dist.prepare_distribution_metadata(
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/pip/_internal/distributions/sdist.py", line 69, in prepare_distribution_metadata
self.req.prepare_metadata()
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/pip/_internal/req/req_install.py", line 580, in prepare_metadata
self.metadata_directory = generate_metadata_legacy(
File "/Users/my.name/.pyenv/versions/3.12.2/lib/python3.12/site-packages/pip/_internal/operations/build/metadata_legacy.py", line 71, in generate_metadata
raise MetadataGenerationFailed(package_details=details) from error
pip._internal.exceptions.MetadataGenerationFailed: metadata generation failed
