Factory Reset of Xavier does not work
I need to do a full factory reset.
While being on 4.2, I wanted to install/upgrade to 4.3 … which failed.
My Xavier has apparently 2 OS installed. Both are broken and using the SDK manager to uninstall/repair does not fix anything.
Read and tried the force recovery + reset button combination multiple times without any success.
Could someone point me to a doc explaining how to perform a (hard?) full factory reset of the Xavier? How could I brick a Xavier by just using the SDK manager?
Thanks,
Rom
  1. How did you make your Xaiver have 2 OS installed?
  2. What was your method to flash the board when you got the out-of-box xavier? Is this your first time to try flashing?
  3. Do you see “nvidia” from lsusb on your host machine after you (tried to) put device into recovery mode?
