FACTORY RESET
So i love the Jetson Nano, infcat i cant wait to buy the NX Xavier (btw when is it coming out?), but i only have 64gb of sd card space, adding a higher space sd card is just a temporary fix. Is there a way of “formating” the jetpack 4.2.2. To start all over again without etching another image? some factory reset
hello yomuevans,
you’re able to access Jetson Nano Developer Kit SD Card Image through download center,
please refer to Write Image to the microSD Card to prepare your microSD card.
thanks
I think you havent understood my question, can i remove all the packages and newly added folders, so as to start again fresh withot removing my sd card?
hello yomuevans,
the quickest way should be flashing your device again.
you may enable SDKManager to flash your board. or, you’d already done it before, system image would be install to your local host by default.
please check ~/nvidia/nvidia_sdk/JetPack_4.3_Linux_GA_P3448/Linux_for_Tegra/ and perform flash script to flash your board.
$ sudo ./flash.sh -r jetson-nano-qspi-sd mmcblk0p1
