Fail flashing Beta2.0 and Beta3.0 on DPX2(P2379,iGPU)
Hi,we successed flashing Alpha2.0 and Beta1.0 by ourselves before.Then we follow https://developer.nvidia.com/drive/driveinstall to flash tegra A and B to Beta2.0 and Beta3.0, we are sure we follow the flashing rule,
1.unplug all usb-serial adaptors from host,
2.exit all minicom terminal windows connected to DPX2
3.make sure DPX2 can connect to internet
4.connect usb cable between DPX2 and Host PC
and we get the flash_fual_tegras.log below. Both of flashing Beta2.0 and 3.0 get the same logs.
we already upgrade my aurix version to v2.02.04.
Our DPX2 autochauffeur only have iGPU.
Is there anything weong?
Successfully acquired lock over /var/lock/LCK..bootburn
Successfully acquired lock over /var/lock/LCK..ttyUSB1
Disabling SIGINT <Ctrl+C> temporarily
Setting Tegra-A on hold... Done
Setting Tegra-B on hold... Done
Setting Tegra-A in recovery... Done
Setting Tegra-B in recovery... Process CMD (49418) still running. Trying to kill after 5 seconds
Done
Enabling SIGINT <Ctrl+C>
==> /home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/_temp_dump/TegraALog_JBHOTfjh8c.txt <==
==> /home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/_temp_dump/TegraBLog_1D3tOLYkqf.txt <==
Target ECID(UID)[99:0] BR_CID: 0x818010016419f1050000000001038080
Detected prod device type
Target ECID(UID)[99:0] BR_CID: 0x818010016419f1050000000001060300
'/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/../../../firmware/t186/mb1//mb1_recovery_prod.bin' -> '/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/_temp_dump/_temp_dump_rWCbNlfNj7/rcm-flash/mb1_recovery.bin'
'/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/../../../firmware/t186/mb1//mb1_prod.bin' -> '/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/_temp_dump/_temp_dump_rWCbNlfNj7/rcm-flash/mb1.bin'
'/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/../../../firmware/t186/mb1//mb1_recovery_prod.bin' -> '/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/_temp_dump/_temp_dump_wflVIlBN96/rcm-flash/mb1_recovery.bin'
'/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/../../../firmware/t186/mb1//mb1_prod.bin' -> '/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/_temp_dump/_temp_dump_wflVIlBN96/rcm-flash/mb1.bin'
Sending MB1
Sending MB1
cat: /sys//devices/pci0000:00/0000:00:15.0/0000:03:00.0/usb3/3-4/3-4.3/busnum: No such file or directory
cat: /sys//devices/pci0000:00/0000:00:15.0/0000:03:00.0/usb3/3-4/3-4.3/devnum: No such file or directory
device node not found
Target instance mismatch.
Previous and new port paths do not match
Tool OutPut:
RCM version 0X180001
Boot Rom communication completed
Tool OutPut to stderr:
'/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/../../../firmware/t186/mts/mce_mts_d15_prod_cr.bin' -> '/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/_temp_dump/_temp_dump_rWCbNlfNj7/rcm-flash/mts-bootpack.bin'
############## Host machine info ##############
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 14.04.5 LTS
Release:	14.04
Codename:	trusty
Linux jeromelin-virtual-machine 4.4.0-31-generic #50~14.04.1-Ubuntu SMP Wed Jul 13 01:07:32 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Target ChipId 0x18 ChipVersion 0x02
##############   Using Binaries ###############
QB: /home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/bootloader/qb_cpu.bin
QB DTB: /home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/bootloader/t186-vcm31t186.dtb
BPMP DTB:/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/platform-support/bpmp_dt/tegra186-a02-bpmp-vcm31-p2379a-000-c00-00-hv.dtb
RCM_Flashing DTB:/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/flash/t18x/rcmkernel/tegra186-vcm31-p2379-flashing-base.dtb
RCM_Flashing Cfg:/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/flash/t18x/quickboot_flashing.cfg
Config file:/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/out/p2379c01-t186a/global_storage.cfg
HyperVisorImage:/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/out/p2379c01-t186a
Generated Image Path: /home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/_temp_dump/_temp_dump_rWCbNlfNj7
SDRAM Config: /home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/../../../platform-support/bct/sdram/E2379_C01_8GB_TA_Samsung_8GB_lpddr4_204MHz_A02.cfg
ADB tool: /home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/../../flash/adb
devOTAFlashOptions file: p2379c01-t186a_A6LVxqnMlH_flashOptions.txt
'/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/../../flash/t18x/rcmkernel/tegra186-vcm31-p2379-flashing-base.dtb' -> '/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/_temp_dump/_temp_dump_rWCbNlfNj7/rcm-flash/linux.dtb'
'/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/../../flash/t18x/rcmfirmware/tegra186-a02-bpmp-vcm31-p2379a-000-c00-00.dtb' -> '/home/jeromelin/DrivePX2/VibranteSDK/vibrante-t186ref-foundation/utils/scripts/bootburn/_temp_dump/_temp_dump_rWCbNlfNj7/rcm-flash/bpmp.dtb'
Generating BCT Files
Generating BR_BCT File
Preserving SkuInfo from Target
Generating MB1_BCT File
Generating Flashing-RCM Images
Sending MB1
Release:	14.04
Codename:	trusty
Sending MB1
Tool OutPut:
Dear JeromeLin,
Did you use DriveInstall 4.1.8.0 Linux SDK to flash DPX2?
And please let me know how to check iGPU and dGPU? Thanks.
