Fail new kernel 3.14.5. With NVIDIA Driver 331.79.
This fails:
make -f scripts/Makefile.build obj=/root/NVIDIA-Linux-x86-331.79/kernel
cc -Wp,-MD,/root/NVIDIA-Linux-x86-331.79/kernel/.nv.o.d -nostdinc -isystem /usr/lib/gcc/i486-linux-gnu/4.8/include -I/usr/src/linux-headers-3.14.5/arch/x86/include -Iarch/x86/include/generated -Iinclude -I/usr/src/linux-headers-3.14.5/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-headers-3.14.5/include/uapi -Iinclude/generated/uapi -include /usr/src/li
nux-headers-3.14.5/include/linux/kconfig.h -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m32 -msoft-float -mregparm=3 -freg-struct-return -mno-mmx -mno-sse -fno-pic -mpreferred-stack-boundary=2 -march=i686 -mtune=generic -maccumulate-outgoing-args -Wa,-mtune=generic32 -ffreestanding -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_CRC32=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -g -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -Werror=implicit-int -Werror=strict-prototypes -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/root/NVIDIA-Linux-x86-331
.79/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.79” -Wno-unused-function -Wuninitialized -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /root/NVIDIA-Linux-x86-331.79/kernel/.tmp_nv.o /root/NVIDIA-Linux-x86-331.79/kernel/nv.c
In file included from /root/NVIDIA-Linux-x86-331.79/kernel/conftest.h:2:0,
from /root/NVIDIA-Linux-x86-331.79/kernel/nv-linux.h:15,
from /root/NVIDIA-Linux-x86-331.79/kernel/nv.c:13:
/root/NVIDIA-Linux-x86-331.79/kernel/conftest/functions.h:24:2: error: #error acpi_walk_namespace() conftest failed!
In file included from /usr/src/linux-headers-3.14.5/arch/x86/include/asm/bitops.h:506:0,
from include/linux/bitops.h:33,
from include/linux/kernel.h:10,
from include/linux/sched.h:15,
from include/linux/utsname.h:5,
from /root/NVIDIA-Linux-x86-331.79/kernel/nv-linux.h:44,
include/linux/bitops.h: En la función ‘hweight_long’:
include/asm-generic/bitops/const_hweight.h:26:70: aviso: signed and unsigned type in conditional expression [-Wsign-compare]
#define hweight32(w) (__builtin_constant_p(w) ? __const_hweight32(w) : __arch_hweight32(w))
include/linux/bitops.h:77:26: nota: in expansion of macro ‘hweight32’
return sizeof(w) == 4 ? hweight32(w) : hweight64(w);
In file included from /usr/src/linux-headers-3.14.5/arch/x86/include/asm/cpumask.h:4:0,
from /usr/src/linux-headers-3.14.5/arch/x86/include/asm/msr.h:10,
from /usr/src/linux-headers-3.14.5/arch/x86/include/asm/processor.h:20,
from /usr/src/linux-headers-3.14.5/arch/x86/include/asm/thread_info.h:22,
from include/linux/thread_info.h:54,
from /usr/src/linux-headers-3.14.5/arch/x86/include/asm/preempt.h:6,
from include/linux/preempt.h:20,
from include/linux/spinlock.h:50,
from include/linux/seqlock.h:35,
from include/linux/time.h:5,
from include/uapi/linux/timex.h:56,
from include/linux/timex.h:56,
from include/linux/sched.h:17,
include/linux/cpumask.h: En la función ‘cpumask_parse’:
include/linux/cpumask.h:603:26: aviso: signed and unsigned type in conditional expression [-Wsign-compare]
int len = nl ? nl - buf : strlen(buf);
In file included from include/uapi/linux/stddef.h:1:0,
from include/linux/stddef.h:4,
from include/linux/posix_types.h:4,
from include/uapi/linux/types.h:13,
from include/linux/types.h:5,
from include/uapi/linux/capability.h:16,
from include/linux/capability.h:15,
from include/linux/sched.h:13,
/usr/src/linux-headers-3.14.5/arch/x86/include/asm/uaccess.h: En la función ‘copy_from_user’:
/usr/src/linux-headers-3.14.5/arch/x86/include/asm/uaccess.h:712:26: aviso: comparación entre expresiones enteras signed y unsigned [-Wsign-compare]
if (likely(sz < 0 || sz >= n))
include/linux/compiler.h:152:40: nota: in definition of macro ‘likely’
# define likely(x) __builtin_expect(!!(x), 1)
/usr/src/linux-headers-3.14.5/arch/x86/include/asm/uaccess.h: En la función ‘copy_to_user’:
/usr/src/linux-headers-3.14.5/arch/x86/include/asm/uaccess.h:730:26: aviso: comparación entre expresiones enteras signed y unsigned [-Wsign-compare]
In file included from /root/NVIDIA-Linux-x86-331.79/kernel/nv.c:13:0:
/root/NVIDIA-Linux-x86-331.79/kernel/nv-linux.h: En el nivel principal:
/root/NVIDIA-Linux-x86-331.79/kernel/nv-linux.h:290:6: aviso: “NV_ACPI_WALK_NAMESPACE_ARGUMENT_COUNT” no está definido [-Wundef]
#if (NV_ACPI_WALK_NAMESPACE_ARGUMENT_COUNT == 6)
/root/NVIDIA-Linux-x86-331.79/kernel/nv-linux.h:292:8: aviso: “NV_ACPI_WALK_NAMESPACE_ARGUMENT_COUNT” no está definido [-Wundef]
#elif (NV_ACPI_WALK_NAMESPACE_ARGUMENT_COUNT == 7)
/root/NVIDIA-Linux-x86-331.79/kernel/nv-linux.h:298:2: error: #error “NV_ACPI_WALK_NAMESPACE_ARGUMENT_COUNT value unrecognized!”
scripts/Makefile.build:308: recipe for target ‘/root/NVIDIA-Linux-x86-331.79/kernel/nv.o’ failed
make[2]: *** [/root/NVIDIA-Linux-x86-331.79/kernel/nv.o] Error 1
Makefile:1274: recipe for target ‘module/root/NVIDIA-Linux-x86-331.79/kernel’ failed
make[1]: *** [module/root/NVIDIA-Linux-x86-331.79/kernel] Error 2
make[1]: Leaving directory ‘/usr/src/linux-headers-3.14.5’
NVIDIA: left KBUILD.
nvidia.ko failed to build!
Makefile:177: recipe for target ‘nvidia.ko’ failed
make: *** [nvidia.ko] Error 1
-> Error.
ERROR: Unable to build the NVIDIA kernel module.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
Solutions?
Greetings.
nvidia-installer.log (9.25 KB)
In the kernel 3.14.4 no fail. :(
Nothing? Or occupied?
