Today I tried installing cuda on my Dell server. The information of my server and gpu is:
uname -a
Linux sem-PowerEdge-T630 4.2.0-27-generic #32~14.04.1-Ubuntu SMP Fri Jan 22 15:32:26 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
lspci | grep NVIDIA
04:00.0 VGA compatible controller: NVIDIA Corporation GM200 [GeForce GTX TITAN X] (rev a1)
04:00.1 Audio device: NVIDIA Corporation Device 0fb0 (rev a1)
my nvidia-driver is 352.39
I install cuda as the following link:
https://devtalk.nvidia.com/default/topic/878117/-solved-titan-x-for-cuda-7-5-login-loop-error-ubuntu-14-04-/, and I try to test cuda.
./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "GeForce GTX TITAN X"
CUDA Driver Version / Runtime Version 7.5 / 7.5
CUDA Capability Major/Minor version number: 5.2
Total amount of global memory: 12288 MBytes (12884705280 bytes)
(24) Multiprocessors, (128) CUDA Cores/MP: 3072 CUDA Cores
GPU Max Clock rate: 1076 MHz (1.08 GHz)
Memory Clock rate: 3505 Mhz
Memory Bus Width: 384-bit
L2 Cache Size: 3145728 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536, 65536), 3D=(4096, 4096, 4096)
Maximum Layered 1D Texture Size, (num) layers 1D=(16384), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(16384, 16384), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 4 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 7.5, CUDA Runtime Version = 7.5, NumDevs = 1, Device0 = GeForce GTX TITAN X
Result = PASS
deviceQuery has no problem.
./bandwidthTest
[CUDA Bandwidth Test] - Starting...
Running on...
Device 0: GeForce GTX TITAN X
Quick Mode
Host to Device Bandwidth, 1 Device(s)
PINNED Memory Transfers
Transfer Size (Bytes) Bandwidth(MB/s)
33554432 12132.0
Device to Host Bandwidth, 1 Device(s)
33554432 12463.3
Device to Device Bandwidth, 1 Device(s)
33554432 249418.5
Result = PASS
NOTE: The CUDA Samples are not meant for performance measurements. Results may vary when GPU Boost is enabled.
bandwidthTest works well for this time, but at the first few times, when I type ./bandwidthTest, the screen stops at
33554432 12463.3
and then reboot.
./transpose
Transpose Starting...
GPU Device 0: "GeForce GTX TITAN X" with compute capability 5.2
> SM Capability 5.2 detected:
> [GeForce GTX TITAN X] has 24 MP(s) x 128 (Cores/MP) = 3072 (Cores)
> Compute performance scaling factor = 1.00
Matrix size: 1024x1024 (64x64 tiles), tile size: 16x16, block size: 16x16
transpose simple copy , Throughput = 229.2142 GB/s, Time = 0.03408 ms, Size = 1048576 fp32 elements, NumDevsUsed = 1, Workgroup = 256
transpose doesn’t work well, it stops at
and then reboot. The server throws an error: pci 1318 fetal error.
I use cuda-gdb to run transpose, it appears like this:
run transpose
Starting program: /home/sem/NVIDIA_CUDA-7.5_Samples/bin/x86_64/linux/release/transpose transpose
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7ffff5013700 (LWP 1934)]
[New Thread 0x7fffec7ff700 (LWP 1935)]
transpose simple copy , Throughput = 126.1617 GB/s, Time = 0.06192 ms, Size = 1048576 fp32 elements, NumDevsUsed = 1, Workgroup = 256
transpose shared memory copy, Throughput = 131.3269 GB/s, Time = 0.05949 ms, Size = 1048576 fp32 elements, NumDevsUsed = 1, Workgroup = 256
transpose naive , Throughput = 65.3947 GB/s, Time = 0.11947 ms, Size = 1048576 fp32 elements, NumDevsUsed = 1, Workgroup = 256
transpose coalesced , Throughput = 127.8565 GB/s, Time = 0.06110 ms, Size = 1048576 fp32 elements, NumDevsUsed = 1, Workgroup = 256
transpose optimized , Throughput = 132.2059 GB/s, Time = 0.05909 ms, Size = 1048576 fp32 elements, NumDevsUsed = 1, Workgroup = 256
transpose coarse-grained , Throughput = 127.2712 GB/s, Time = 0.06138 ms, Size = 1048576 fp32 elements, NumDevsUsed = 1, Workgroup = 256
transpose fine-grained , Throughput = 134.0107 GB/s, Time = 0.05830 ms, Size = 1048576 fp32 elements, NumDevsUsed = 1, Workgroup = 256
Connection closed by foreign host.
the screen again stops, and then reboot.
I am rather confused. Any help?
