all show up normal. And the error show large amount of Read-only file system error while trying to flash the file to the drive.
19:25:22.547 - Info: ***************************************
19:25:22.547 - Info: * *
19:25:22.547 - Info: * Step 3: Start the flashing process *
19:26:16.799 - Info: Model: PCIe SSD (nvme)
19:26:16.799 - Info: Disk /dev/nvme0n1: 512GB
19:26:16.799 - Info: Sector size (logical/physical): 512B/512B
19:26:16.799 - Info: Partition Table: gpt
19:26:16.799 - Info: Disk Flags:
19:26:16.799 - Info: Number Start End Size File system Name Flags
19:26:16.799 - Info: 2 20.5kB 134MB 134MB A_kernel msftdata
19:26:16.799 - Info: 3 134MB 135MB 786kB A_kernel-dtb msftdata
19:26:16.799 - Info: 4 135MB 168MB 33.2MB A_reserved_on_user msftdata
19:26:16.799 - Info: 5 168MB 302MB 134MB B_kernel msftdata
19:26:16.799 - Info: 6 302MB 303MB 786kB B_kernel-dtb msftdata
19:26:16.799 - Info: 7 303MB 336MB 33.2MB B_reserved_on_user msftdata
19:26:16.799 - Info: 8 336MB 420MB 83.9MB recovery msftdata
19:26:16.799 - Info: 9 420MB 421MB 524kB recovery-dtb msftdata
19:26:16.799 - Info: 10 421MB 488MB 67.1MB fat32 esp boot, esp
19:26:16.799 - Info: 11 488MB 572MB 83.9MB recovery_alt msftdata
19:26:16.799 - Info: 12 572MB 572MB 524kB recovery-dtb_alt msftdata
19:26:16.799 - Info: 13 572MB 639MB 67.1MB esp_alt msftdata
19:26:16.799 - Info: 14 639MB 1059MB 419MB UDA msftdata
19:26:16.799 - Info: 15 1059MB 1562MB 503MB reserved msftdata
19:26:16.799 - Info: 1 1562MB 61.2GB 59.6GB ext4 APP msftdata
19:26:16.799 - Info: [ 29]: l4t_flash_from_kernel: Expanding last partition to fill the storage device
19:26:16.833 - Info: [ 29]: l4t_flash_from_kernel: Successfully create gpt for external device
19:26:16.834 - Info: [ 29]: l4t_flash_from_kernel: Starting to flash to emmc
19:26:16.835 - Info: Active index file is /mnt/internal/flash.idx
19:26:16.835 - Info: Flash index file is /mnt/internal/flash.idx
19:26:16.835 - Info: Number of lines is 61
19:26:16.835 - Info: [ 29]: l4t_flash_from_kernel: Starting to flash to external device
19:26:16.835 - Info: max_index=60
19:26:16.835 - Info: Active index file is /mnt/external/flash.idx
19:26:16.836 - Info: Number of lines is 18
19:26:16.836 - Info: max_index=17
19:26:16.843 - Info: [ 29]: l4t_flash_from_kernel: Starting to flash to qspi
19:26:16.849 - Info: QSPI storage size: 67108864 bytes.
19:26:16.853 - Info: writing item=0, 9:0:master_boot_record, 0, 512, mbr_9_0.bin, 512, fixed-<reserved>-0, 694898d1c345bdb31b377790ed7fc0b0db184bf7
19:26:16.868 - Info: writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed-<reserved>-0, 31ceb69198233b1d8fcbc7b34ba35436539a07aa
19:26:16.884 - Info: writing item=2, 9:0:A_kernel, 20480, 134217728, boot.img, 58963968, fixed-<reserved>-2, 0cdf00c36ee7b104169d811c359ce9ae4d98f9ee
19:26:16.917 - Info: Writing A_kernel partition with boot.img
19:26:16.919 - Info: Get size of partition through connection.
19:26:17.049 - Info: 58963968 bytes from /mnt/external/boot.img to /dev/nvme0n1: 1KB block=57582 remainder=0
19:26:17.049 - Info: dd if=/mnt/external/boot.img of=/dev/nvme0n1 bs=1K skip=0 seek=20 count=57582
19:26:17.955 - Info: [ 30]: l4t_flash_from_kernel: Successfully flash the emmc
19:26:20.072 - Info: 57582+0 records in
19:26:20.072 - Info: 57582+0 records out
19:26:20.072 - Info: 58963968 bytes (59 MB, 56 MiB) copied, 3.02176 s, 19.5 MB/s
19:26:20.078 - Info: Writing A_kernel partition done
19:26:20.093 - Info: writing item=3, 9:0:A_kernel-dtb, 134238208, 786432, kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb, 249353, fixed-<reserved>-3, a26ad92d82c63ade216bc8ec55583fac0f6e8a0f
19:26:20.124 - Info: Writing A_kernel-dtb partition with kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb
19:26:20.125 - Info: Get size of partition through connection.
19:26:20.156 - Info: 249353 bytes from /mnt/external/kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb to /dev/nvme0n1: 1KB block=243 remainder=521
19:26:20.156 - Info: dd if=/mnt/external/kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb of=/dev/nvme0n1 bs=1K skip=0 seek=131092 count=243
19:26:20.160 - Info: 243+0 records in
19:26:20.160 - Info: 243+0 records out
19:26:20.160 - Info: 248832 bytes (249 kB, 243 KiB) copied, 0.0032368 s, 76.9 MB/s
19:26:20.162 - Info: dd if=/mnt/external/kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb of=/dev/nvme0n1 bs=1 skip=248832 seek=134487040 count=521
19:26:20.164 - Info: 521+0 records in
19:26:20.164 - Info: 521+0 records out
19:26:20.164 - Info: 521 bytes copied, 0.00108426 s, 481 kB/s
19:26:20.167 - Info: Writing A_kernel-dtb partition done
19:26:20.180 - Info: writing item=4, 9:0:A_reserved_on_user, 135024640, 33161216, , , fixed-<reserved>-4,
19:26:20.209 - Info: [ 33]: l4t_flash_from_kernel: Warning: skip writing A_reserved_on_user partition as no image is specified
19:26:20.222 - Info: writing item=5, 9:0:B_kernel, 168185856, 134217728, boot.img, 58963968, fixed-<reserved>-5, 0cdf00c36ee7b104169d811c359ce9ae4d98f9ee
19:26:20.253 - Info: Writing B_kernel partition with boot.img
19:26:20.254 - Info: Get size of partition through connection.
19:26:20.270 - Info: 58963968 bytes from /mnt/external/boot.img to /dev/nvme0n1: 1KB block=57582 remainder=0
19:26:20.270 - Info: dd if=/mnt/external/boot.img of=/dev/nvme0n1 bs=1K skip=0 seek=164244 count=57582
19:26:20.829 - Info: 57582+0 records in
19:26:20.829 - Info: 57582+0 records out
19:26:20.829 - Info: 58963968 bytes (59 MB, 56 MiB) copied, 0.557137 s, 106 MB/s
19:26:20.832 - Info: Writing B_kernel partition done
19:26:20.845 - Info: writing item=6, 9:0:B_kernel-dtb, 302403584, 786432, kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb, 249353, fixed-<reserved>-6, a26ad92d82c63ade216bc8ec55583fac0f6e8a0f
19:26:20.875 - Info: Writing B_kernel-dtb partition with kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb
19:26:20.876 - Info: Get size of partition through connection.
19:26:20.896 - Info: 249353 bytes from /mnt/external/kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb to /dev/nvme0n1: 1KB block=243 remainder=521
19:26:20.896 - Info: dd if=/mnt/external/kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb of=/dev/nvme0n1 bs=1K skip=0 seek=295316 count=243
19:26:20.900 - Info: 243+0 records in
19:26:20.900 - Info: 243+0 records out
19:26:20.900 - Info: 248832 bytes (249 kB, 243 KiB) copied, 0.00323494 s, 76.9 MB/s
19:26:20.902 - Info: dd if=/mnt/external/kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb of=/dev/nvme0n1 bs=1 skip=248832 seek=302652416 count=521
19:26:20.905 - Info: 521+0 records in
19:26:20.905 - Info: 521+0 records out
19:26:20.905 - Info: 521 bytes copied, 0.00113344 s, 460 kB/s
19:26:20.908 - Info: Writing B_kernel-dtb partition done
19:26:20.920 - Info: writing item=7, 9:0:B_reserved_on_user, 303190016, 33161216, , , fixed-<reserved>-7,
19:26:20.951 - Info: [ 33]: l4t_flash_from_kernel: Warning: skip writing B_reserved_on_user partition as no image is specified
19:26:20.964 - Info: writing item=8, 9:0:recovery, 336351232, 83886080, recovery.img, 64065536, fixed-<reserved>-8, f36ea6576155fc5e43efb90e7e705844084819e1
19:26:20.995 - Info: Writing recovery partition with recovery.img
19:26:20.996 - Info: Get size of partition through connection.
19:26:21.116 - Info: 64065536 bytes from /mnt/external/recovery.img to /dev/nvme0n1: 1KB block=62564 remainder=0
19:26:21.116 - Info: dd if=/mnt/external/recovery.img of=/dev/nvme0n1 bs=1K skip=0 seek=328468 count=62564
19:26:24.395 - Info: 62564+0 records in
19:26:24.395 - Info: 62564+0 records out
19:26:24.395 - Info: 64065536 bytes (64 MB, 61 MiB) copied, 3.27698 s, 19.6 MB/s
19:26:24.399 - Info: Writing recovery partition done
19:26:24.413 - Info: writing item=9, 9:0:recovery-dtb, 420237312, 524288, tegra234-p3768-0000+p3767-0005-nv-super.dtb.rec, 249353, fixed-<reserved>-9, a26ad92d82c63ade216bc8ec55583fac0f6e8a0f
19:26:24.445 - Info: Writing recovery-dtb partition with tegra234-p3768-0000+p3767-0005-nv-super.dtb.rec
19:26:24.447 - Info: Get size of partition through connection.
19:26:24.477 - Info: 249353 bytes from /mnt/external/tegra234-p3768-0000+p3767-0005-nv-super.dtb.rec to /dev/nvme0n1: 1KB block=243 remainder=521
19:26:24.477 - Info: dd if=/mnt/external/tegra234-p3768-0000+p3767-0005-nv-super.dtb.rec of=/dev/nvme0n1 bs=1K skip=0 seek=410388 count=243
19:26:24.482 - Info: 243+0 records in
19:26:24.482 - Info: 243+0 records out
19:26:24.482 - Info: 248832 bytes (249 kB, 243 KiB) copied, 0.00340797 s, 73.0 MB/s
19:26:24.483 - Info: dd if=/mnt/external/tegra234-p3768-0000+p3767-0005-nv-super.dtb.rec of=/dev/nvme0n1 bs=1 skip=248832 seek=420486144 count=521
19:26:24.485 - Info: 521+0 records in
19:26:24.485 - Info: 521+0 records out
19:26:24.485 - Info: 521 bytes copied, 0.00109098 s, 478 kB/s
19:26:24.489 - Info: Writing recovery-dtb partition done
19:26:24.502 - Info: writing item=10, 9:0:esp, 420761600, 67108864, esp.img, 67108864, fixed-<reserved>-10, 6e9081a09e15d438ba61eb56e04cdf259554ceda
19:26:24.531 - Info: Writing esp partition with esp.img
19:26:24.532 - Info: Get size of partition through connection.
19:26:24.653 - Info: 67108864 bytes from /mnt/external/esp.img to /dev/nvme0n1: 1KB block=65536 remainder=0
19:26:24.653 - Info: dd if=/mnt/external/esp.img of=/dev/nvme0n1 bs=1K skip=0 seek=410900 count=65536
19:26:28.052 - Info: 65536+0 records in
19:26:28.052 - Info: 65536+0 records out
19:26:28.052 - Info: 67108864 bytes (67 MB, 64 MiB) copied, 3.39767 s, 19.8 MB/s
19:26:28.056 - Info: Writing esp partition done
19:26:28.068 - Info: writing item=11, 9:0:recovery_alt, 487870464, 83886080, , , fixed-<reserved>-11,
19:26:28.100 - Info: [ 41]: l4t_flash_from_kernel: Warning: skip writing recovery_alt partition as no image is specified
19:26:28.112 - Info: writing item=12, 9:0:recovery-dtb_alt, 571756544, 524288, , , fixed-<reserved>-12,
19:26:28.143 - Info: [ 41]: l4t_flash_from_kernel: Warning: skip writing recovery-dtb_alt partition as no image is specified
19:26:28.156 - Info: writing item=13, 9:0:esp_alt, 572280832, 67108864, , , fixed-<reserved>-13,
19:26:28.185 - Info: [ 41]: l4t_flash_from_kernel: Warning: skip writing esp_alt partition as no image is specified
19:26:28.199 - Info: writing item=14, 9:0:UDA, 639401984, 419430400, , , fixed-<reserved>-14,
19:26:28.211 - Info: [ 41]: l4t_flash_from_kernel: Skip writing UDA partition
19:26:28.224 - Info: writing item=15, 9:0:reserved, 1058832384, 502792192, , , fixed-<reserved>-15,
19:26:28.254 - Info: [ 41]: l4t_flash_from_kernel: Warning: skip writing reserved partition as no image is specified
19:26:28.267 - Info: writing item=16, 9:0:APP, 1561624576, 59641638912, , , expand-<reserved>-1,
19:26:28.449 - Info: Formatting APP partition /dev/nvme0n1p1 ...
19:26:28.484 - Info: mke2fs 1.46.5 (30-Dec-2021)
19:26:28.501 - Info: Discarding device blocks: 0/124645641 done
19:26:28.501 - Info: Creating filesystem with 124645641 4k blocks and 31162368 inodes
19:26:28.501 - Info: Filesystem UUID: be839674-a840-4edb-88a2-3db52d137520
19:26:28.501 - Info: Superblock backups stored on blocks:
19:26:28.501 - Info: 32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
19:26:28.501 - Info: 4096000, 7962624, 11239424, 20480000, 23887872, 71663616, 78675968,
19:26:28.501 - Info: 102400000
19:26:28.501 - Info: Allocating group tables: 0/3804 done
19:26:28.597 - Info: Writing inode tables: 0/3804 done
19:26:28.602 - Info: Creating journal (262144 blocks): done
19:26:28.602 - Info: Writing superblocks and filesystem accounting information: 0/3804 done
19:26:28.792 - Info: Formatting APP parition done
19:26:28.834 - Info: Formatting APP partition /dev/nvme0n1p1 ...
19:26:28.834 - Info: tar --checkpoint-action="ttyout=Hit %s checkpoint #%u%*\r" -x -I 'zstd -T0' -pf /mnt/external/system.img --warning=no-timestamp --numeric-owner --xattrs --xattrs-include=* -C /tmp/ci-StwlyK03zX
19:26:42.375 - Info: tar: ./usr/lib/thunderbird/libxul.so: Cannot utime: Read-only file system
19:26:42.375 - Info: tar: ./usr/lib/thunderbird/libxul.so: Cannot change ownership to uid 0, gid 0: Read-only file system
19:26:42.375 - Info: tar: ./usr/lib/thunderbird/libxul.so: Cannot change mode to rw-r--r--: Read-only file system
19:26:43.461 - Info: tar: ./usr/lib/thunderbird/omni.ja: Cannot open: No such device or address
19:26:43.461 - Info: tar: ./usr/lib/thunderbird/isp: Cannot mkdir: Input/output error
19:26:43.461 - Info: tar: ./usr/lib/thunderbird/isp/DSPAM.sfd: Cannot open: Input/output error```
