I am using the Jetpack 6.2 SDK to flash the Orin NX core board. When I use the devkit, it can be flashed normally. However, when I use the customized carrier board, it stops at booting into RCM mode. Our carrier board completely follows the devkit design for the USB part for flashing.
The flashing command I am using is:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p “-c bootloader/generic/cfg/flash_t234_qspi.xml” --showlogs --network usb0 jetson-orin-nano-devkit-super internal
The log printed by the flashing terminal is as follows:
Entering RCM boot
[ 0.0290 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.0291 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.0291 ] rcm boot with presigned binaries
[ 0.0295 ] tegrarcm_v2 --instance 3-1 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0298 ] BR_CID: 0x80012344705DF3C95000000001FF81C0
[ 0.0384 ] Sending bct_br
[ 0.0472 ] Sending mb1
[ 0.0478 ] Sending psc_bl1
[ 0.0583 ] Sending bct_mb1
[ 0.0650 ] Generating blob for T23x
[ 0.0664 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.0668 ] The number of images in blob is 19
[ 0.0673 ] blobsize is 100081089
[ 0.0674 ] Added binary blob_uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt of size 2043968
[ 0.1239 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[ 0.1246 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[ 0.1251 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[ 0.1254 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279808
[ 0.1258 ] Not supported type: mb2_applet
[ 0.1259 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 440944
[ 0.1264 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 0.1267 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[ 0.1276 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12070576
[ 0.1374 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.1400 ] Added binary blob_bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt of size 1027008
[ 0.1409 ] Added binary blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt of size 383296
[ 0.1415 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[ 0.1420 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 415008
[ 0.1424 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.1429 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1887312
[ 0.1434 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.1439 ] Added binary blob_boot0.img of size 77246464
[ 0.1997 ] Added binary blob_tegra234-p3768-0000+p3767-0000-nv.dtb of size 249505
[ 0.2687 ] tegrarcm_v2 --instance 3-1 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.2691 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[ 0.3260 ] Sending bct_mem
[ 0.3379 ] Sending blob
[ 4.6421 ] RCM-boot started/home/platform/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra
*- Step 3: Start the flashing process *
Waiting for target to boot-up…
Timeout
Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.
Cleaning up…
The serial port output log is as follows:
serial.txt (25.2 KB)
May I ask what could be the reason that the BL cannot enter RCM boot mode? Does the EEPROM on the Carrie board need to be programmed with additional firmware?
Please guide me if there is any issue with the operation. Thank you!
