Fail to Install TensorRT 10.3.0.26 for DeepStream 7.1
• Hardware Platform (Jetson / GPU) NVIDIA GeForce RTX 4070 Laptop GPU
• DeepStream Version 7.1
• TensorRT Version 10.3.0.26
Trying to install DeepStream 7.1 in a fresh Ubuntu 22.04. In the step Install TensorRT 10.3.0.26 step of guideline the follow error occurs:
eduardo@eduardo:~$ version=“10.3.0.26-1+cuda12.5”
sudo apt-get install libnvinfer-dev=${version} libnvinfer-dispatch-dev=${version} libnvinfer-dispatch10=${version} libnvinfer-headers-dev=${version}
libnvinfer-headers-plugin-dev=${version} libnvinfer-lean-dev=${version} libnvinfer-lean10=${version} libnvinfer-plugin-dev=${version} libnvinfer-plugin10=${version}
libnvinfer-vc-plugin-dev=${version} libnvinfer-vc-plugin10=${version} libnvinfer10=${version} libnvonnxparsers-dev=${version} libnvonnxparsers10=${version} tensorrt-dev=${version}
[sudo] password for eduardo:
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libnvinfer-dev : Depends: libnvinfer10 (= 10.3.0.26-1+cuda12.5) but 10.5.0.18-1+cuda12.6 is to be installed
E: Unable to correct problems, you have held broken packages.
libnvinfer-headers-plugin-dev=10.3.0.26-1+cuda12.5: command not found
libnvinfer-vc-plugin-dev=10.3.0.26-1+cuda12.5: command not found
Note: All applicable previous steps of the guideline where performed.
The guideline is: Installation — DeepStream documentation
I managed to install Tensorrt following this guideline: Installation Guide :: NVIDIA Deep Learning TensorRT Documentation
os=“ubuntu2204”
tag=“10.3.0-cuda-12.5” sudo dpkg -i nv-tensorrt-local-repo-${os}-${tag}_1.0-1_amd64.deb sudo cp /var/nv-tensorrt-local-repo-${os}-${tag}/*-keyring.gpg /usr/share/keyrings/
sudo apt-get update
sudo apt-get install tensorrt
Now the installation of Deepstream-7.1 is completed and working.
Glad to know it’s working now.
