zcs
1
Hi, I try to mmap the capture_plane of decoder, but it return error.
I have modifed “00_video_decode” to reproduce this issue.
ret = dec->capture_plane.setupPlane(V4L2_MEMORY_MMAP, min_dec_capture_buffers+ 5, true, false);
then it failed and print “Error in decoder capture plane setup”
Is there any advice?
Hi zcs, please share the purpose of the change.
zcs
3
Hi, DaneLLL
I want to map capture plane buffer of decoder to modify YUV data.
Please try new APIs in r28.1
NvBufferMemMap
NvBufferMemUnMap
zcs
5
Hi DaneLLL,
Thank you for your reply. I will try it.
What is the difference between NvBufferMemMap and mmap?
Not sure how mmap is implemented. NvBufferMemMap is new APIs to fix off-sync issues on r24.2.1
A relative topic:
[url]msync with MS_SYNC option failure - Jetson TX1 - NVIDIA Developer Forums
