hi. Recently, I want to run app on nano, but I get some confusing errors. the detailed information is as follows:
ERROR: getPluginCreator could not find plugin FancyActivation version 001 namespace
ERROR: Cannot deserialize plugin FancyActivation
ERROR: getPluginCreator could not find plugin ResizeNearest version 001 namespace
ERROR: Cannot deserialize plugin ResizeNearest
I guess these errors may caused by TensorRT. So I hope someone have solved this problem could give me a solution. thanks a lot.
We will need more information to give a further suggestion.
Based on the log you shared, there are some plugin implementation inside your model.
So please remember add the corresponding plugin layer when deserializing the model.
hi, bro. thank you for your answer. Actually, I don’t put any plugin layer inside my model. And I just transplant my apps from windows10 to ubuntu 18.04, so i don’t know whether there are some difference between windows10 and ubuntu on transforming trt model. could you please give some suggestions? thanks a lot.
hi,
you mean i should reinstall TensortRT on Linux? I have installed tensorrt on Linux, but i still use yolo.weights on darknet with windows, should I retrain my model file on linux?
Hi, bro. Thanks for your answer. I have been running my program on windows before. This is a program about video analysis. Since I bought nano, I intend to transplant some function in the program to nano, so I recently compiled and run my program on linux. At the same time, I also converted my model I train on windows. But I have encountered such a problem, I will take your advice just use the official sample. Thanks a lot.
For YOLO, it’s recommended to check our deepstream SDK first.
There is a sample to demonstrate how to enable YOLOv2, YOLOv2_tiny, YOLOv3 and YOLOv3_tiny on Nano. https://developer.nvidia.com/deepstream-sdk
