I reinstall the system to CentOS5.2 and the reinstall the PGI7.2. It is quite smooth to install the comipler. I also start the ‘lmgrd.rc start’
but when I use it to compile my test program, it shows
pgi-cc-lin64: LICENSE MANAGER PROBLEM: Failed to checkout license
pgi-cc-lin64: LICENSE MANAGER PROBLEM: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature: pgi-cc-lin64
Server name: x.y.w.z
License path: /opt/pgi/license.dat:
FLEXnet Licensing error:-15,570. System Error: 115 “Operation now in progress”
For further information, refer to the FLEXnet Licensing documentation,
available at “www.macrovision.com”.
At the beginning, I have the hostname set as ‘linux’ in the webpage of PGI whne downloading the premanent license, but I find that it is not consistent with my ip address so I recreate a license key (the hostid is the same, I am sure).
Moreover, when I run “lmgrd.rc stop”, it shows
lmutil - Copyright (c) 1989-2007 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
Shutdown failed: Cannot connect to license server system. (-15,570:115 “Operation now in progress”)
and I try to run lmgrd directly, it shows
18:44:20 (lmgrd) -----------------------------------------------
18:44:20 (lmgrd) Please Note:
18:44:20 (lmgrd)
18:44:20 (lmgrd) This log is intended for debug purposes only.
18:44:20 (lmgrd) In order to capture accurate license
18:44:20 (lmgrd) usage data into an organized repository,
18:44:20 (lmgrd) please enable report logging. Use Macrovision’s
18:44:20 (lmgrd) software license administration solution,
18:44:20 (lmgrd) FLEXnet Manager, to readily gain visibility
18:44:20 (lmgrd) into license usage data and to create
18:44:20 (lmgrd) insightful reports on critical information like
18:44:20 (lmgrd) license availability and usage. FLEXnet Manager
18:44:20 (lmgrd) can be fully automated to run these reports on
18:44:20 (lmgrd) schedule and can be used to track license
18:44:20 (lmgrd) servers and usage across a heterogeneous
18:44:20 (lmgrd) network of servers including Windows NT, Linux
18:44:20 (lmgrd) and UNIX. Contact Macrovision at
18:44:20 (lmgrd) www.macrovision.com for more details on how to
18:44:20 (lmgrd) obtain an evaluation copy of FLEXnet Manager
18:44:20 (lmgrd) for your enterprise.
18:44:20 (lmgrd)
18:44:20 (lmgrd)
18:44:20 (lmgrd)
18:44:20 (lmgrd) The license server manager (lmgrd) running as root:
18:44:20 (lmgrd) This is a potential security problem
18:44:20 (lmgrd) and is not recommended.
[root@139 tmp]# 18:44:20 (lmgrd) Failed to open the TCP port number in the license.
So everytime when doing compilation, it will so this message? Is it normal? WHY “TCP_NODELAY NOT enabled” ? Does it matter?
By the way, it seems that PGI only need to verify the license once (and I have to turn off the firewall), and later on, it no more connect to the remote server to verify the license during compilation, so I can turn the firewall on, right?
Sorry you are having problems. With a firewall, users usually have to
assign a specific port both th elmgrd and pgroupd daemons, and then
tell the firewall to let them through those ports.
The hostname is usually the output of
lmutil lmhostid -hostname
while the hostid is the output of
lmutil lmhostid
This extracts the hostname from /etc/hosts and the hostid is the
MAC address of eth0.
Often, with DNS, the /etc/hosts file is only used with the hostname
‘localhost’ or ‘localhost.localdomain’. In this case, try locahost or
Once you have determined the hostname (for example, ‘foo’),
edit the license file by hand
SERVER foo 0123456789ab 27000
DAEMON pgroupd
should become
DAEMON pgroupd PORT=7496
and tell the firewall to allow lmgrd through 27000,
and pgroupd through 7496.
We read the license on every execution, so you need
to keep the license server running.
Thank you so much for your reply. I’ve already change the hostid in the license.dat manually. Well, I just quite confuse for one thing. For the very first time when I use pgi to compile my source, it trying to connect and verify my lience remotely, at this time, I must turn off the firewall to make it work (just adding the port 27000 in the firewall doesn’t work). And later on, by adding the port 27000 and let the firewall turn on, it works (forever)!?
If the hostid changes, you must regenerate a new license online.
If the hostname changes, you can edit the license by hand.
I did not tell you what to do with the Firewall in a specific way,
because I do not know what Firewall you are using. In general,
Firewalls have a way to let daemons or processes through
designated ports. The lmgrd port shoudl be the same for all the
flexlm licenses you are running on the machine. The pgroupd daemon, and
the other daemons for other licensed software, should each have a
unique port number.
I believe your license PIN is 512176, a single user, node-locked license.
The compilers can only run on the same machine the license server
is running on.
