nvidia@nvidia-desktop:~/mkl3/mkl-dnn/build$ sudo make
[sudo] password for nvidia:
[ 1%] Building CXX object src/CMakeFiles/mkldnn.dir/common/batch_normalization.cpp.o
[ 1%] Building CXX object src/CMakeFiles/mkldnn.dir/common/convolution.cpp.o
[ 2%] Building CXX object src/CMakeFiles/mkldnn.dir/common/convolution_relu.cpp.o
[ 3%] Building CXX object src/CMakeFiles/mkldnn.dir/common/engine.cpp.o
[ 4%] Building CXX object src/CMakeFiles/mkldnn.dir/common/inner_product.cpp.o
[ 4%] Building CXX object src/CMakeFiles/mkldnn.dir/common/lrn.cpp.o
[ 5%] Building CXX object src/CMakeFiles/mkldnn.dir/common/memory.cpp.o
[ 6%] Building CXX object src/CMakeFiles/mkldnn.dir/common/memory_desc_wrapper.cpp.o
[ 7%] Building CXX object src/CMakeFiles/mkldnn.dir/common/pooling.cpp.o
[ 8%] Building CXX object src/CMakeFiles/mkldnn.dir/common/primitive.cpp.o
[ 8%] Building CXX object src/CMakeFiles/mkldnn.dir/common/primitive_desc.cpp.o
[ 9%] Building CXX object src/CMakeFiles/mkldnn.dir/common/primitive_iterator.cpp.o
[ 10%] Building CXX object src/CMakeFiles/mkldnn.dir/common/query.cpp.o
[ 11%] Building CXX object src/CMakeFiles/mkldnn.dir/common/relu.cpp.o
[ 11%] Building CXX object src/CMakeFiles/mkldnn.dir/common/reorder.cpp.o
[ 12%] Building CXX object src/CMakeFiles/mkldnn.dir/common/softmax.cpp.o
[ 13%] Building CXX object src/CMakeFiles/mkldnn.dir/common/stream.cpp.o
[ 14%] Building CXX object src/CMakeFiles/mkldnn.dir/cpu/cpu_barrier.cpp.o
In file included from /home/nvidia/mkl3/mkl-dnn/src/cpu/jit_generator.hpp:28:0,
from /home/nvidia/mkl3/mkl-dnn/src/cpu/cpu_barrier.hpp:22,
from /home/nvidia/mkl3/mkl-dnn/src/cpu/cpu_barrier.cpp:19:
/home/nvidia/mkl3/mkl-dnn/src/cpu/xbyak/xbyak_util.h:84:12: fatal error: cpuid.h: No such file or directory
#include <cpuid.h>
compilation terminated.
src/CMakeFiles/mkldnn.dir/build.make:313: recipe for target ‘src/CMakeFiles/mkldnn.dir/cpu/cpu_barrier.cpp.o’ failed
make[2]: *** [src/CMakeFiles/mkldnn.dir/cpu/cpu_barrier.cpp.o] Error 1
CMakeFiles/Makefile2:238: recipe for target ‘src/CMakeFiles/mkldnn.dir/all’ failed
make[1]: *** [src/CMakeFiles/mkldnn.dir/all] Error 2
Makefile:145: recipe for target ‘all’ failed
make: *** [all] Error 2
Would you mind checking if the mkldnn supports the ARM system or not first?
