Failed building TensorRT OSS on Jetson Nano 2GB
• Hardware (Jetson Nano 2GB)
• Jetpack Version (4.5)
• Tao-converter version:jp45
I want to install Tao-converter on my Jetson Nano, I followed every steps in this document. At step 5, the instructions to build TensorRT OSS said after building ends successfully, libnvinfer_plugin.so* will be generated under ‘pwd’/out/. But there is no such file and not even the out folder. I can not figure what did I do wrong, please help.
Do you use the command shared in the below section:
https://docs.nvidia.com/tao/tao-toolkit/text/object_detection/yolo_v4.html#tensorrt-oss-on-jetson-arm64
If yes, you can find the library at [pwd]/out/.
If it doesn’t exist, please check if the library is generated within the build folder.
Thank you for your reply, I did use the command you shared. There was no [pwd]/out/ folder and nothing generated within the build folder.
Is there any error when compiling?
Would you mind sharing the complete output log with us?
