Failed flashing Jetson Thor for the first time
I’m having issues with r39.2. The failure is during package install using apt. See output below. What am I missing?
jetsoninstaller-r39.2.0-2026-06-01-23-53-13-arm64.iso
███████████████████ Installing many packages, wait for 15mins.. ██████████████████████ \";"
start: subiquity/Late/run/command_16: curtin in-target -- apt purge -y unattended-upgrades whoopsie
finish: subiquity/Late/run/command_16: curtin in-target -- apt purge -y unattended-upgrades whoopsie
start: subiquity/Late/run/command_17: curtin in-target -- nv-update-initrd
finish: subiquity/Late/run/command_17: Command '['systemd-cat', '--level-prefix=false', '--identifier=subiquity_log.2150', 'sh', '-c', 'curtin in-target -- nv-update-initrd']' returned non-zero exit status 127.
finish: subiquity/Late/run: Command '['systemd-cat', '--level-prefix=false', '--identifier=subiquity_log.2150', 'sh', '-c', 'curtin in-target -- nv-update-initrd']' returned non-zero exit status 127.
finish: subiquity/Install/install: Command '['systemd-cat', '--level-prefix=false', '--identifier=subiquity_log.2150', 'sh', '-c', 'curtin in-target -- nv-update-initrd']' returned non-zero exit status 127.
start: subiquity/ErrorReporter/1751465304.378308058.install_fail/add_info:
finish: subiquity/ErrorReporter/1751465304.378308058.install_fail/add_info: written to /var/crash/1751465304.378308058.install_fail.crash
An error occurred. Press enter to start a shell
screenlog.txt (493.1 KB)
You could try again later. I’m doing something related to the iso and ubuntu apt repository has timed out 3 times in one hour when attempting to download some small *.deb packages.
And the Jetpack 7.2.1 iso has some improvments. If you have bandwidth to download it might be worthwhile. https://developer.nvidia.com/embedded/jetpack/downloads/archive-7.2.1
I tried again but no luck. I actually thing the apt repo is on the USB and doesn’t require internet. Seems its the nv-update-initrd failing, which stops the entire install and then Grub never gets updated.
I tried jetpack 7.2.1 but same error unfortunately
I resolved this. For others, the issue was the microSD adapter I was using for the ISO. Switching to a Sandisk Cruser Blade 64GB has resulted in the install completing. No internet connection was needed for the install.
