After the TX2 device that has been in use is powered on for a certain time, it suddenly fails to start, and repeats the cycle alarm:
[0[0000.160] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
Aux Info = 0x0, Reason = 0x1c
[0[0000.155] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0[0000.154] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
After I use the command (sudo ./flash jetson-tx2 mmcblk0p1) to flash the machine again, the flashing fails, and the flashing log is as follows:
# L4T BSP Information:
# R32 , REVISION: 5.1
# Target Board Information:
# Name: jetson-tx2, Board Family: t186ref, SoC: Tegra 186,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
./tegraflash.py --chip 0x18 --applet "/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0060 ] Generating RCM messages
[ 0.0108 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0149 ] RCM 0 is saved as rcm_0.rcm
[ 0.0184 ] RCM 1 is saved as rcm_1.rcm
[ 0.0184 ] List of rcm files are saved in rcm_list.xml
[ 0.0184 ]
[ 0.0185 ] Signing RCM messages
[ 0.0268 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0282 ] Assuming zero filled SBK key
[ 0.0319 ]
[ 0.0320 ] Copying signature to RCM mesages
[ 0.0389 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0405 ]
[ 0.0406 ] Boot Rom communication
[ 0.0415 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0440 ] RCM version 0X180001
[ 0.0450 ] Boot Rom communication completed
[ 1.0572 ]
[ 2.0597 ] tegrarcm_v2 --isapplet
[ 2.0605 ] Applet version 01.00.0000
[ 2.0837 ]
[ 2.0856 ] Retrieving EEPROM data
[ 2.0857 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/cvm.bin
[ 2.0869 ] Applet version 01.00.0000
[ 2.1048 ] Saved platform info in /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/cvm.bin
[ 2.1789 ]
Board ID(3310) version(D00) sku(1000) revision(F.0)
Copy /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb.rec
copying bctfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_lpddr4_A02_l4t.cfg)... done.
copying misc_config(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)... done.
copying pinmux_config(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)... done.
copying pmic_config(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg)... done.
copying pmc_config(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)... done.
copying prod_config(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)... done.
copying scr_config(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)... done.
copying scr_cold_boot_config(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)... done.
copying bootrom_config(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)... done.
copying dev_params(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)... done.
Existing bootloader(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying initrd(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to rootfs... done.
Making Boot image... done.
/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x18 --key --cmd sign boot.img
version 1.0.0
[ 0.0006 ] Generating signature
[ 0.0091 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0104 ] Assuming zero filled SBK key
[ 0.0104 ]
[ 0.0105 ] sign_type : 0
[ 0.0106 ] header_magic: 414e4452
[ 0.0173 ] tegrahost_v2 --chip 0x18 --align 1_boot.img
[ 0.0489 ]
[ 0.0561 ] tegrahost_v2 --appendsigheader 1_boot.img zerosbk
[ 0.0588 ]
[ 0.0611 ] tegrasign_v2 --key --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 0.0620 ] Assuming zero filled SBK key
[ 0.0824 ]
[ 0.0842 ] tegrahost_v2 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[ 0.0862 ]
[ 0.0871 ] Signed file: /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x18: Don't need to do anything
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
~/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/ramdisk_tmp ~/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader ~/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra
30402 块
_BASE_KERNEL_VERSION=4.9.201-tegra
~/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/ramdisk_tmp/lib ~/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/ramdisk_tmp ~/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader ~/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra
65752 块
Making Recovery image...
copying recdtbfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb.rec)... done.
记录了20+0 的读入
记录了20+0 的写出
20 bytes copied, 0.000182127 s, 110 kB/s
Existing sosfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)... done.
Existing cpu_bootloader(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
Existing mb2blfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)... done.
Existing scefile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing spefile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/spe.bin) reused.
Existing drameccfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/dram-ecc.bin) reused.
Existing badpagefile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)... done.
Existing tosfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/tos-trusty.img) reused.
Existing eksfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
Copying nv_boot_control.conf to rootfs
/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x18 --key --cmd sign kernel_tegra186-quill-p3310-1000-c03-00-base.dtb
version 1.0.0
[ 0.0066 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0107 ] Assuming zero filled SBK key
[ 0.0109 ]
[ 0.0111 ] sign_type : 762080361
[ 0.0111 ] header_magic: d00dfeed
[ 0.0124 ] tegrahost_v2 --chip 0x18 --align 1_kernel_tegra186-quill-p3310-1000-c03-00-base.dtb
[ 0.0143 ]
[ 0.0189 ] tegrahost_v2 --appendsigheader 1_kernel_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 0.0213 ]
[ 0.0263 ] tegrasign_v2 --key --list 1_kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0278 ] Assuming zero filled SBK key
[ 0.0417 ]
[ 0.0451 ] tegrahost_v2 --updatesigheader 1_kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt 1_kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 0.0469 ]
[ 0.0474 ] Signed file: /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
done.
Making system.img...
populating rootfs from /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/rootfs ... done.
populating /boot/extlinux/extlinux.conf ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image... done.
system.img built successfully.
Existing tbcfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
copying cfgfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml... done.
Existing flasher(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config P3310_A00_8GB_lpddr4_A02_l4t.cfg --odmdata 0x7090000 --applet mb1_recovery_prod.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --bins "mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos-trusty.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb"
saving flash command in /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0139 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0161 ] Assuming zero filled SBK key
[ 0.0928 ]
[ 0.0930 ] Generating RCM messages
[ 0.1079 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[ 0.1099 ] RCM 0 is saved as rcm_0.rcm
[ 0.1585 ] RCM 1 is saved as rcm_1.rcm
[ 0.1588 ] List of rcm files are saved in rcm_list.xml
[ 0.1637 ]
[ 0.1638 ] Signing RCM messages
[ 0.1653 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.1670 ] Assuming zero filled SBK key
[ 0.1738 ]
[ 0.1738 ] Copying signature to RCM mesages
[ 0.1757 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.1847 ]
[ 0.1847 ] Parsing partition layout
[ 0.2046 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.2446 ]
[ 0.2446 ] Creating list of images to be signed
[ 0.2584 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 3.1751 ]
[ 3.1752 ] Generating signatures
[ 3.1768 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 3.1781 ] Assuming zero filled SBK key
[ 4.9921 ]
[ 4.9922 ] Generating br-bct
[ 5.1804 ] Updating dev and MSS params in BR BCT
[ 5.1806 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18 0
[ 5.3222 ]
[ 5.3222 ] Updating bl info
[ 5.3230 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 5.3699 ]
[ 5.3699 ] Updating smd info
[ 5.3708 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[ 5.3996 ]
[ 5.3997 ] Updating Odmdata
[ 5.4005 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatefields Odmdata =0x7090000
[ 5.4314 ]
[ 5.4315 ] Get Signed section of bct
[ 5.4325 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --listbct bct_list.xml
[ 5.4421 ]
[ 5.4433 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 5.4446 ] Assuming zero filled SBK key
[ 5.4449 ]
[ 5.4449 ] Updating BCT with signature
[ 5.4460 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatesig bct_list_signed.xml
[ 5.4663 ]
[ 5.4664 ] Generating coldboot mb1-bct
[ 5.4674 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 5.4680 ] MB1-BCT version: 0xf
[ 5.4682 ] Packing sdram param for instance[0]
[ 5.4908 ] Packing sdram param for instance[1]
[ 5.4910 ] Packing sdram param for instance[2]
[ 5.4911 ] Packing sdram param for instance[3]
[ 5.5066 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 5.5070 ] Appending platform config data of size :- 3032
[ 5.5240 ] Parsing config file :mobile_scr.cfg
[ 5.5242 ] Appending platform config data of size :- 12240
[ 5.5585 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 5.5588 ] Appending platform config data of size :- 24
[ 5.6656 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 5.6665 ] Appending platform config data of size :- 672
[ 5.6712 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 5.6722 ] Appending platform config data of size :- 64
[ 5.6758 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 5.6767 ] Appending platform config data of size :- 1628
[ 5.6823 ]
[ 5.6824 ] Updating mb1-bct with firmware information
[ 5.6844 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 5.6864 ] MB1-BCT version: 0xf
[ 5.6980 ]
[ 5.6980 ] Updating mb1-bct with storage information
[ 5.7002 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 5.7018 ] MB1-BCT version: 0xf
[ 5.7325 ]
[ 5.7343 ] tegrahost_v2 --chip 0x18 --align mb1_cold_boot_bct_MB1.bct
[ 5.7354 ]
[ 5.7360 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 5.7370 ]
[ 5.7380 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 5.7386 ] Assuming zero filled SBK key
[ 5.7402 ]
[ 5.7411 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 5.7519 ]
[ 5.7520 ] Generating recovery mb1-bct
[ 5.7529 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 5.7534 ] MB1-BCT version: 0xf
[ 5.7535 ] Packing sdram param for instance[0]
[ 5.7754 ] Packing sdram param for instance[1]
[ 5.7756 ] Packing sdram param for instance[2]
[ 5.7757 ] Packing sdram param for instance[3]
[ 5.7758 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 5.7760 ] Appending platform config data of size :- 3032
[ 5.7762 ] Parsing config file :minimal_scr.cfg
[ 5.7763 ] Appending platform config data of size :- 12240
[ 5.8055 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 5.8057 ] Appending platform config data of size :- 24
[ 5.8057 ]
[ 5.8057 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 5.8057 ] Appending platform config data of size :- 672
[ 5.8057 ]
[ 5.8057 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 5.8057 ] Appending platform config data of size :- 64
[ 5.8057 ]
[ 5.8057 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 5.8057 ] Appending platform config data of size :- 1628
[ 5.8058 ]
[ 5.8058 ] Updating mb1-bct with firmware information
[ 5.8067 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 5.8074 ] MB1-BCT version: 0xf
[ 5.8335 ]
[ 5.8336 ] Updating mb1-bct with storage information
[ 5.8348 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 5.8355 ] MB1-BCT version: 0xf
[ 5.8673 ]
[ 5.8682 ] tegrahost_v2 --chip 0x18 --align mb1_bct_MB1.bct
[ 5.8689 ]
[ 5.8694 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 5.8700 ]
[ 5.8706 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 5.8711 ] Assuming zero filled SBK key
[ 5.8722 ]
[ 5.8729 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 5.8819 ]
[ 5.8820 ] Copying signatures
[ 5.8832 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 8.5622 ]
[ 8.5623 ] Boot Rom communication
[ 8.5642 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
[ 8.5658 ] BootRom is not running
[ 13.6170 ]
[ 14.6202 ] tegrarcm_v2 --isapplet
[ 14.6218 ] Applet version 01.00.0000
[ 14.6246 ]
[ 14.6247 ] Sending BCTs
[ 14.6263 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 14.6277 ] Applet version 01.00.0000
[ 14.6445 ] Sending bct_bootrom
[ 14.6447 ] [................................................] 100%
[ 14.6457 ] Sending bct_mb1
[ 14.6468 ] [................................................] 100%
[ 14.6636 ]
[ 14.6637 ] Generating blob
[ 14.6646 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery_cpu.bin
[ 14.6652 ]
[ 14.6658 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 14.6665 ]
[ 14.6671 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 14.6676 ] Assuming zero filled SBK key
[ 14.6716 ]
[ 14.6725 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 14.6732 ]
[ 14.6739 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery.bin
[ 14.6744 ]
[ 14.6749 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 14.7195 ]
[ 14.7218 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 14.7232 ] Assuming zero filled SBK key
[ 14.7286 ]
[ 14.7304 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 14.7324 ]
[ 14.7341 ] tegrahost_v2 --chip 0x18 --align blob_preboot_d15_prod_cr.bin
[ 14.7360 ]
[ 14.7376 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 14.7390 ]
[ 14.7406 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 14.7417 ] Assuming zero filled SBK key
[ 14.7443 ]
[ 14.7455 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 14.7468 ]
[ 14.7479 ] tegrahost_v2 --chip 0x18 --align blob_mce_mts_d15_prod_cr.bin
[ 14.7490 ]
[ 14.7500 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 14.7555 ]
[ 14.7572 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 14.7643 ] Assuming zero filled SBK key
[ 14.8046 ]
[ 14.8056 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 14.8214 ]
[ 14.8229 ] tegrahost_v2 --chip 0x18 --align blob_bpmp.bin
[ 14.8241 ]
[ 14.8250 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[ 14.8262 ]
[ 14.8270 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 14.8275 ] Assuming zero filled SBK key
[ 14.8373 ]
[ 14.8382 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 14.8394 ]
[ 14.8403 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb
[ 14.8413 ]
[ 14.8424 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb zerosbk
[ 14.8441 ]
[ 14.8454 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 14.8461 ] Assuming zero filled SBK key
[ 14.8601 ]
[ 14.8613 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 14.8625 ]
[ 14.8631 ] tegrahost_v2 --chip 0x18 --align blob_tos-trusty.img
[ 14.8636 ]
[ 14.8641 ] tegrahost_v2 --appendsigheader blob_tos-trusty.img zerosbk
[ 14.8651 ]
[ 14.8658 ] tegrasign_v2 --key None --list blob_tos-trusty_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 14.8663 ] Assuming zero filled SBK key
[ 14.8735 ]
[ 14.8752 ] tegrahost_v2 --updatesigheader blob_tos-trusty_sigheader.img.encrypt blob_tos-trusty_sigheader.img.hash zerosbk
[ 14.8766 ]
[ 14.8774 ] tegrahost_v2 --chip 0x18 --align blob_eks.img
[ 14.8782 ]
[ 14.8788 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[ 14.8795 ]
[ 14.8803 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 14.8809 ] Assuming zero filled SBK key
[ 14.8811 ]
[ 14.8850 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 14.8866 ]
[ 14.8876 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-quill-p3310-1000-c03-00-base.dtb
[ 14.8883 ]
[ 14.8889 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 14.8897 ]
[ 14.8905 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 14.8910 ] Assuming zero filled SBK key
[ 14.8956 ]
[ 14.8963 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 14.8970 ]
[ 14.8977 ] tegrahost_v2 --chip 0x18 --generateblob blob.xml blob.bin
[ 14.8982 ] number of images in blob are 9
[ 14.8983 ] blobsize is 4247272
[ 14.8984 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 221776
[ 14.8996 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 90176
[ 14.8998 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 63104
[ 14.9000 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2082144
[ 14.9008 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 534816
[ 14.9012 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt of size 605120
[ 14.9020 ] Added binary blob_tos-trusty_sigheader.img.encrypt of size 395072
[ 14.9022 ] Added binary blob_eks_sigheader.img.encrypt of size 1440
[ 14.9023 ] Added binary blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt of size 253472
[ 14.9050 ]
[ 14.9051 ] Sending bootloader and pre-requisite binaries
[ 14.9065 ] tegrarcm_v2 --download blob blob.bin
[ 14.9076 ] Applet version 01.00.0000
[ 14.9103 ] Sending blob
[ 15.0326 ]
Error: Return value 1
Command tegrarcm_v2 --download blob blob.bin
Failed flashing t186ref.
So, I need your help, thanks!
