hello,my deepstream version is 7.1.0, and my deepstream-python pipline code:
def _create_pipeline_elements(self):
source = Gst.ElementFactory.make("rtspsrc", "rtsp-source")
source.set_property('location', self.video_source)
source.set_property('latency', 300)
source.set_property('protocols', 'tcp')
source.set_property('tcp-timeout', 100000000) # 10s TCP超时
source.set_property("do-rtcp", True)
source.set_property("retry", 5)
source.set_property("timeout", 5)
\# source.set_property('drop-on-latency', True)
self.pad_added_handler_id = source.connect("pad-added", self.on_pad_added)
self.rtpdepay = Gst.ElementFactory.make("rtph264depay", "rtp-h264-depay")
h264parser = Gst.ElementFactory.make("h264parse", "h264-parser")
decoder = Gst.ElementFactory.make("nvv4l2decoder", "nv-decoder")
decoder.set_property("enable-max-performance", True)
self.pipeline.add(source)
self.pipeline.add(self.rtpdepay)
self.pipeline.add(h264parser)
self.pipeline.add(decoder)
assert self.rtpdepay.link(h264parser)
assert h264parser.link(decoder)
queue_before_mux = Gst.ElementFactory.make("queue", "queue-before-mux")
self.pipeline.add(queue_before_mux)
assert decoder.link(queue_before_mux)
nvvidconv_pre_mux = Gst.ElementFactory.make("nvvideoconvert", "pre-mux-converter")
nvvidconv_pre_mux.set_property('compute-hw', 1)
\# nvvidconv_pre_mux.set_property('nvbuf-memory-type', 2)
self.pipeline.add(nvvidconv_pre_mux)
caps_str = f"video/x-raw(memory:NVMM), width={self.stream_width}, height={self.stream_height}, format=NV12"
caps_filter = Gst.ElementFactory.make("capsfilter", "pre-mux-capsfilter")
caps_filter.set_property("caps", Gst.Caps.from_string(caps_str))
self.pipeline.add(caps_filter)
assert queue_before_mux.link(nvvidconv_pre_mux)
assert nvvidconv_pre_mux.link(caps_filter)
\# 2. nvstreammux
streammux = Gst.ElementFactory.make("nvstreammux", "stream-muxer")
self.pipeline.add(streammux)
streammux.set_property('live-source', True)
streammux.set_property('width', self.stream_width)
streammux.set_property('height', self.stream_height)
streammux.set_property('batch-size', 1)
streammux.set_property('batched-push-timeout', 50000)
sinkpad = streammux.get_request_pad("sink_0")
srcpad = caps_filter.get_static_pad("src")
assert srcpad.link(sinkpad) == Gst.PadLinkReturn.OK
\# 3. 串联创建所有推理(nvinfer)元件
last_element = streammux
for idx, m in enumerate(self.models):
pgie = Gst.ElementFactory.make("nvinfer", f"primary-inference-{idx}")
pgie.set_property('config-file-path', m\['config'\])
component_id = idx + 1
pgie.set_property('unique-id', component_id)
self.model_id_map\[component_id\] = {
'name': m\['name'\],
'class_filter': m\['class_filter'\]
self.pipeline.add(pgie)
assert last_element.link(pgie)
last_element = pgie
tracker = Gst.ElementFactory.make("nvtracker", "shared-tracker")
tracker_config_path = self.models\[0\]\['tracker_cfg'\]
cfg = configparser.ConfigParser()
cfg.read(tracker_config_path)
for k, v in cfg\['tracker'\].items():
try:
tracker.set_property(k, int(v))
except (ValueError, TypeError):
tracker.set_property(k, v)
self.pipeline.add(tracker)
assert last_element.link(tracker)
last_element = tracker
tracker_src_pad = tracker.get_static_pad("src")
tracker_src_pad.add_probe(
Gst.PadProbeType.BUFFER,
self.\_probe_all_models,
None)
nvvidconv_post = Gst.ElementFactory.make("nvvideoconvert", "convertor-post")
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
nvosd.set_property("process-mode", 0)
gpu_conv_out = Gst.ElementFactory.make("nvvideoconvert", "gpu-convert-out")
cpu_conv_out = Gst.ElementFactory.make("videoconvert", "cpu-convert-out")
\# appsink
appsink = Gst.ElementFactory.make("appsink", "appsink-final")
appsink.set_property("emit-signals", True)
appsink.set_property("sync", False)
appsink.set_property("max-buffers", 5)
appsink.set_property("drop", True)
appsink.set_property("caps", Gst.Caps.from_string(f"video/x-raw,format=BGR"))
appsink.connect("new-sample", self.\_on_new_sample, 0)
final_elements = (nvvidconv_post, nvosd, gpu_conv_out, cpu_conv_out, appsink)
for elem in final_elements:
self.pipeline.add(elem)
assert last_element.link(nvvidconv_post)
assert nvvidconv_post.link(nvosd)
assert nvosd.link(gpu_conv_out)
assert gpu_conv_out.link(cpu_conv_out)
assert cpu_conv_out.link(appsink)
