Failed in mem copy
INFO — Combined image saved successfully to /home/intelli-sbc/intelli-scope/java/RIV/input/2026-10-12_13-14-21~e113e663-96b6-4cee-b0e4-f118fe54ddd1/01_008740_2026-10-12-13-18-49.988_293.744.jpg
cuGraphicsEGLRegisterImage failed: 700, cuda process stop
/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform_copy.cpp:341: => Failed in mem copy
0:07:19.276908883 2676 0xffff142b21e0 WARN nvinfer gstnvinfer.cpp:2194:gst_nvinfer_submit_input_buffer: error: Failed to set cuda device 0
*** Unable to set device in gst_nvdewarper_dewarp Line 945
0:07:19.277030200 2676 0xffff1552cc00 ERROR nvdewarper gstnvdewarper.cpp:1032:gst_nvdewarper_transform: gst_nvdewarper_dewarp failed
0:07:19.277042552 2676 0xffff142b21e0 WARN nvinfer gstnvinfer.cpp:2194:gst_nvinfer_submit_input_buffer: error: cudaSetDevice failed with error cudaErrorCudartUnloading
0:07:19.277258208 2676 0xffff142b21e0 ERROR nvinfer gstnvinfer.cpp:1240:get_converted_buffer: cudaMemset2DAsync failed with error cudaErrorCudartUnloading while converting buffer
0:07:19.277287137 2676 0xffff142b21e0 WARN nvinfer gstnvinfer.cpp:1576:gst_nvinfer_process_full_frame: error: Buffer conversion failed
Error: gst-resource-error-quark: Failed to set cuda device 0 (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(2194): gst_nvinfer_submit_input_buffer (): /GstPipeline:pipeline0/GstNvInfer:primary-nvinference-engine:
2026-10-12 13:18:50,467 — [deepstream] — INFO — Execution time: 438.6147 seconds
2026-10-12 13:18:50,467 — [deepstream] — INFO — Pipeline: Stopping pipeline…
Unable to set device in gst_nvstreammux_change_state
2026-10-12 13:18:50,468 — [deepstream] — ERROR — Pipeline: state change to NULL did not complete cleanly (ret=, state=, pending=); giving it extra time to settle before releasing references
*** Unable to set device in gst_nvvideoconvert_transform Line 3486
0:07:19.301352101 2676 0xffff1552cc60 ERROR nvvideoconvert gstnvvideoconvert.c:4280:gst_nvvideoconvert_transform: Set Device failed
0:07:19.301443272 2676 0xffff1552cc60 WARN basesrc gstbasesrc.c:3127:gst_base_src_loop: error: Internal data stream error.
0:07:19.301465385 2676 0xffff1552cc60 WARN basesrc gstbasesrc.c:3127:gst_base_src_loop: error: streaming stopped, reason error (-5)
0:07:19.301557388 2676 0xffff1552cc60 WARN queue gstqueue.c:992:gst_queue_handle_sink_event: error: Internal data stream error.
0:07:19.301575565 2676 0xffff1552cc60 WARN queue gstqueue.c:992:gst_queue_handle_sink_event: error: streaming stopped, reason error (-5)
0:07:19.304786305 2676 0xffff142b2300 ERROR nvvideoconvert gstnvvideoconvert.c:4280:gst_nvvideoconvert_transform: Set Device failed
0:07:19.304852867 2676 0xffff142b2300 WARN basesrc gstbasesrc.c:3127:gst_base_src_loop: error: Internal data stream error.
0:07:19.304878436 2676 0xffff142b2300 WARN basesrc gstbasesrc.c:3127:gst_base_src_loop: error: streaming stopped, reason error (-5)
(Argus) Error InvalidState: Argus client is exiting with 2 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 366)
WARNING Argus: 12 client objects still exist during shutdown:
281473522668416 (0xfffeb4001140)
281473523024080 (0xfffea0001140)
281473526232624 (0xfffeb4000ed0)
281473547312224 (0xfffea0000ed0)
281473547312384 (0xfffea0001350)
281473547312576 (0xfffea0001240)
281473547317584 (0xfffeb4001350)
281473547317728 (0xfffeb4001240)
281473547322224 (0xfffea0003430)
281473547330760 (0xfffea0003548)
281473547334064 (0xfffeb4002af0)
281473547342536 (0xfffeb4002c08) facing this issue even after switcing some plugins to vic and copy-hw =2, still facing this issue. kindly help using deepstream 7.1 and jetpack 6.2.0
Hi @shubhangi972003,
The errors you are observing may be related to a previously reported memory-copy issue with DeepStream 7.1 on JetPack 6.2.
The error cuGraphicsEGLRegisterImage failed: 700 indicates a CUDA illegal memory access. Subsequent CUDA errors may be secondary failures.
NVIDIA documents a similar issue in the DeepStream FAQ and recommends using JetPack 6.1 with DeepStream 7.1 or setting copy-hw=2 on nvvideoconvert as a workaround.
Since you mentioned applying copy-hw=2 to only some plugins, could you try setting it on all nvvideoconvert instances and verify that they use surface-array memory? A similar forum discussion recommends this approach.
If the issue persists, could you please share your complete pipeline and confirm whether the same behavior occurs with JetPack 6.1?
Hope this helps,
Julian Camacho
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
• DeepStream Version
• TensorRT Version
