Failed Re-Flashing Jetson Xavier NX
I have a Jetson AGX XAVIER devkit board from NVIDIA which i’m trying to re-flash. i’ve followed instructions from Quick Start — Jetson Linux<br/>Developer Guide 34.1 documentation and used this image Jetson Linux | NVIDIA Developer for my attempt. I’m installing from Ubuntu
Below are the logs:
valid@typebot:~/jetson/Linux_for_Tegra$ sudo ./flash.sh  jetson-agx-xavier-devkit mmcblk0p1
# L4T BSP Information:
# R35 , REVISION: 6.2
# User release: 0.0
ECID is 0x88021911647e25c70800000013008100
# Target Board Information:
# Name: jetson-agx-xavier-devkit, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying soft_fuses(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/valid/jetson/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0069 ] Generating RCM messages
[   0.0084 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/valid/jetson/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[   0.0087 ] Header already present for /home/valid/jetson/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[   0.0151 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0151 ] Assuming zero filled SBK key
[   0.0166 ] tegrasign_v3.py --file /home/valid/jetson/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0166 ] Assuming zero filled SBK key
[   0.0179 ] Warning: pub_key.key is not found
[   0.0163 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/valid/jetson/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/valid/jetson/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[   0.0200 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[   0.0216 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/valid/jetson/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[   0.0218 ] RCM 0 is saved as rcm_0.rcm
[   0.0237 ] RCM 1 is saved as rcm_1.rcm
[   0.0239 ] RCM 2 is saved as rcm_2.rcm
[   0.0239 ] List of rcm files are saved in rcm_list.xml
[   0.0239 ]
[   0.0239 ] Signing RCM messages
[   0.0281 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   0.0281 ] Assuming zero filled SBK key
[   0.0297 ] Warning: pub_key.key is not found
[   0.0268 ] Copying signature to RCM mesages
[   0.0280 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.0286 ] Boot Rom communication
[   0.0298 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[   0.0299 ] RCM version 0X190001
[   0.0515 ] Boot Rom communication completed
[   2.0734 ] tegrarcm_v2 --isapplet
[   2.0740 ] Applet version 01.00.0000
[   2.1011 ] tegrarcm_v2 --ismb2
[   2.1329 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194_aligned.bin
[   2.1346 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194_aligned.bin zerosbk
[   2.1349 ] adding BCH for nvtboot_applet_t194_aligned.bin
[   2.1411 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   2.1412 ] Assuming zero filled SBK key
[   2.1420 ] Warning: pub_key.key is not found
[   2.1404 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_aligned_sigheader.bin.encrypt nvtboot_applet_t194_aligned_sigheader.bin.hash zerosbk
[   2.1430 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[   2.1431 ] Applet version 01.00.0000
[   2.1675 ] Sending mb2
[   2.1675 ] [................................................] 100%
[   2.1882 ] tegrarcm_v2 --boot recovery
[   2.1884 ] Applet version 01.00.0000
[   3.2203 ] tegrarcm_v2 --isapplet
[   3.2472 ] tegrarcm_v2 --ismb2
[   3.2474 ] MB2 Applet version 01.00.0000
[   3.2797 ] tegrarcm_v2 --ismb2
[   3.2798 ] MB2 Applet version 01.00.0000
[   3.3117 ] Retrieving board information
[   3.3131 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[   3.3134 ] MB2 Applet version 01.00.0000
[   3.3470 ] Saved platform info in chip_info.bin
[   3.3517 ] Chip minor revision: 2
[   3.3518 ] Bootrom revision: 0xf
[   3.3519 ] Ram code: 0x2
[   3.3520 ] Chip sku: 0xd0
[   3.3520 ] Chip Sample: non es
[   3.3528 ] Retrieving EEPROM data
[   3.3528 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/valid/jetson/Linux_for_Tegra/bootloader/cvm.bin
[   3.3532 ] MB2 Applet version 01.00.0000
[   3.3787 ] Saved platform info in /home/valid/jetson/Linux_for_Tegra/bootloader/cvm.bin
[   3.4204 ] Rebooting to recovery mode
[   3.4218 ] tegrarcm_v2 --ismb2
[   3.4220 ] MB2 Applet version 01.00.0000
[   3.4472 ] Rebooting to recovery mode
[   3.4488 ] tegrarcm_v2 --reboot recovery
[   3.4491 ] MB2 Applet version 01.00.0000
Board ID(2888) FAB(400) sku(0004) revision(M.0)
lz4c installed at /usr/bin/lz4c
Compressing /home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb ...
Copy /home/valid/jetson/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb to /home/valid/jetson/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb.rec
NVDISP+UEFI in bootloader/nvdisp-init.bin ..
copying bctfile(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)... done.
copying bctfile1(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying uphy_config(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)... done.
copying minratchet_config(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg)... done.
copying device_config(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)... done.
copying misc_cold_boot_config(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)... done.
copying gpioint_config(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)... done.
copying pmic_config(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)... done.
copying pmc_config(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)... done.
copying prod_config(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)... done.
copying scr_config(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying scr_cold_boot_config(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying bootrom_config(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)... done.
copying dev_params(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)... done.
copying dev_params_b(/home/valid/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct_b-sdmmc.cfg)... done.
Existing bootloader(/home/valid/jetson/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/valid/jetson/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/valid/jetson/Linux_for_Tegra/bootloader/ramdisk_tmp /home/valid/jetson/Linux_for_Tegra/bootloader /home/valid/jetson/Linux_for_Tegra
42011 blocks
gzip: /home/valid/jetson/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.10.216-tegra
command is failed
is there perhaps something i’m doing wrong? Thanks for your time.
What is your bsp version? Seems like you are using r35.6.2.
Please refer to Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
Do you apply below commands below flash?
$ tar xf ${L4T_RELEASE_PACKAGE}
$ sudo tar xpf ${SAMPLE_FS_PACKAGE} -C Linux_for_Tegra/rootfs/
$ cd Linux_for_Tegra/
$ sudo ./apply_binaries.sh
$ sudo ./tools/l4t_flash_prerequisites.sh
Hi David, thanks for the response.my current BSP version is indeed 35.6.2 which should be the latest compatible version with my board(?) via the compatibility matrix. It seems like the documentation site i used before missed the l4t_flash_prerequisites step. I’ve deleted the previously extracted files and re-ran all the commands above before flashing. unfortunately i’m still getting the same error. below are the logs from the most recent attempt
# User release: 0.0
/home/valid/jetson/Linux_for_Tegra/bootloader/tegraflash_internal.py:1199: SyntaxWarning: invalid escape sequence '\.'
  patt = re.compile(".*(mbr|gpt).*\.bin")
/home/valid/jetson/Linux_for_Tegra/bootloader/tegraflash_internal.py:1315: SyntaxWarning: invalid escape sequence '\.'
/home/valid/jetson/Linux_for_Tegra/bootloader/tegraflash_internal.py:4522: SyntaxWarning: invalid escape sequence '\s'
  m = re.search('bpmp_fw_dtb[\s]+([\w._-]+)', values['--bins'])
/home/valid/jetson/Linux_for_Tegra/bootloader/tegrasign_v3_internal.py:1036: SyntaxWarning: invalid escape sequence '\d'
  m = re.search('Key size is (\d+)', ret_str)
/home/valid/jetson/Linux_for_Tegra/bootloader/tegrasign_v3_internal.py:1507: SyntaxWarning: invalid escape sequence '\d'
  pattd = re.compile('kdf_args_' + temp_stem + '(\d).yaml')
/home/valid/jetson/Linux_for_Tegra/bootloader/tegraflash_impl_t234.py:1387: SyntaxWarning: invalid escape sequence '\s'
/home/valid/jetson/Linux_for_Tegra/bootloader/tegraflash_impl_t234.py:2720: SyntaxWarning: invalid escape sequence '\.'
/home/valid/jetson/Linux_for_Tegra/bootloader/tegraflash_impl_t234.py:2771: SyntaxWarning: invalid escape sequence '\/'
  info_print("Copying enc\/signed file in " + output_dir)
version 1.0.0
[   0.0210 ] Generating RCM messages
[   0.0233 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/valid/jetson/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[   0.0236 ] Header already present for /home/valid/jetson/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[   0.0367 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0368 ] Assuming zero filled SBK key
[   0.0381 ] tegrasign_v3.py --file /home/valid/jetson/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0382 ] Assuming zero filled SBK key
[   0.0442 ] Warning: pub_key.key is not found
[   0.0378 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/valid/jetson/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/valid/jetson/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[   0.0439 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[   0.0481 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/valid/jetson/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[   0.0482 ] RCM 0 is saved as rcm_0.rcm
[   0.0504 ] RCM 1 is saved as rcm_1.rcm
[   0.0505 ] RCM 2 is saved as rcm_2.rcm
[   0.0505 ] List of rcm files are saved in rcm_list.xml
[   0.0505 ]
[   0.0505 ] Signing RCM messages
[   0.0595 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   0.0596 ] Assuming zero filled SBK key
[   0.0612 ] Warning: pub_key.key is not found
[   0.0535 ] Copying signature to RCM mesages
[   0.0547 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.0553 ] Boot Rom communication
[   0.0566 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[   0.0568 ] RCM version 0X190001
[   0.0788 ] Boot Rom communication completed
[   2.1020 ] tegrarcm_v2 --isapplet
[   2.1025 ] Applet version 01.00.0000
[   2.1277 ] tegrarcm_v2 --ismb2
[   2.1868 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194_aligned.bin
[   2.1883 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194_aligned.bin zerosbk
[   2.1886 ] adding BCH for nvtboot_applet_t194_aligned.bin
[   2.1996 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   2.1996 ] Assuming zero filled SBK key
[   2.2003 ] Warning: pub_key.key is not found
[   2.1939 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_aligned_sigheader.bin.encrypt nvtboot_applet_t194_aligned_sigheader.bin.hash zerosbk
[   2.1963 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[   2.1965 ] Applet version 01.00.0000
[   2.2211 ] Sending mb2
[   2.2212 ] [................................................] 100%
[   2.2408 ] tegrarcm_v2 --boot recovery
[   2.2410 ] Applet version 01.00.0000
[   3.2711 ] tegrarcm_v2 --isapplet
[   3.2976 ] tegrarcm_v2 --ismb2
[   3.2979 ] MB2 Applet version 01.00.0000
[   3.3320 ] tegrarcm_v2 --ismb2
[   3.3322 ] MB2 Applet version 01.00.0000
[   3.3642 ] Retrieving board information
[   3.3655 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[   3.3657 ] MB2 Applet version 01.00.0000
[   3.3976 ] Saved platform info in chip_info.bin
[   3.4019 ] Chip minor revision: 2
[   3.4020 ] Bootrom revision: 0xf
[   3.4020 ] Ram code: 0x2
[   3.4020 ] Chip sku: 0xd0
[   3.4021 ] Chip Sample: non es
[   3.4029 ] Retrieving EEPROM data
[   3.4029 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/valid/jetson/Linux_for_Tegra/bootloader/cvm.bin
[   3.4033 ] MB2 Applet version 01.00.0000
[   3.4298 ] Saved platform info in /home/valid/jetson/Linux_for_Tegra/bootloader/cvm.bin
[   3.4734 ] Rebooting to recovery mode
[   3.4748 ] tegrarcm_v2 --ismb2
[   3.4751 ] MB2 Applet version 01.00.0000
[   3.4989 ] Rebooting to recovery mode
[   3.5001 ] tegrarcm_v2 --reboot recovery
[   3.5003 ] MB2 Applet version 01.00.0000
bl is uefi
42011 blocks
command is failed
Please provide the serial console log for us to review.
Some questions to confirm:
  • Is your AGX Xavier a dev kit or a custom board?
  • Is your ubuntu a native or a virtual machine?
Sorry for the very late reply. I wasn’t able to get a micro-usb cable to hook up the serial console at that time. I ended up downloading the nvidia sdk-manager desktop app under an ubuntu vm with the appropriate os version. Flashing through the desktop app by usb passthrough ended up working. Thanks anyways!
