We are porting IMX378 sensor from JetPack3.3 to JetPack4.2.
However, the following error occurs:
nvidia@nvidia-desktop:~$ dmesg | grep imx378
[ 0.184620] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-imx378.dts
[ 0.441643] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-imx378.dts
[ 3.694327] imx378 30-001a: Failed to find port index
[ 3.694331] imx378 30-001a: Failed to find port info.
[ 3.694334] imx378 30-001a: Failed to initialize imx378
[ 3.694337] imx378 30-001a: tegra camera driver registration failed
[ 3.694518] imx378: probe of 30-001a failed with error -22
The same phenomenon occurs even if imx378.c source code is ported to imx219.c or imx185.c.
Is there a problem with the following device tree?
File1: /usr/src/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-imx378.dts
#include "tegra186-quill-p3310-1000-c03-00-base.dts"
#include "quill-platforms/tegra186-quill-camera-imx378-c03.dtsi"
nvidia,dtsfilename = __FILE__;
/* GPIO */
gpio@2200000 {
camera-control-input {
status = "disabled";
camera-control-output-low {
camera-control-output-high {
gpio-hog;
gpios = <CAM0_RST_L 0 CAM0_PWDN 0>;
label = "cam0-rst cam0-pwdn";
output-high;
status = "okay";
host1x {
vi_base: vi@15700000 {
ports {
imx378_vi_port0: port@0 {
status = "okay";
imx378_vi_in0: endpoint {
status = "okay";
csi_base: nvcsi@150c0000 {
csi_chan0: channel@0 {
status = "okay";
ports {
csi_chan0_port0: port@0 {
status = "okay";
imx378_csi_in0: endpoint@0 {
status = "okay";
csi_chan0_port1: port@1 {
status = "okay";
imx378_csi_out0: endpoint@1 {
status = "okay";
File2: /usr/src/hardware/nvidia/platform/t18x/quill/kernel-dts/quill-platforms/tegra186-quill-camera-imx378-c03.dtsi
#include <quill-modules/tegra186-camera-imx378-c03.dtsi>
#include "dt-bindings/clock/tegra186-clock.h"
#define CAM0_RST_L TEGRA_MAIN_GPIO(R, 5)
#define CAM0_PWDN TEGRA_MAIN_GPIO(R, 0)
#define CAM1_RST_L TEGRA_MAIN_GPIO(R, 1)
#define CAM1_PWDN TEGRA_MAIN_GPIO(L, 6)
/* camera control gpio definitions */
i2c@3180000 {
tca9548@70 {
compatible = "nxp,pca9548";
reg = <0x70>;
#address-cells = <1>;
#size-cells = <0>;
skip_mux_detect = "yes";
#vif-supply = <&en_vdd_cam>;
vcc-supply = <&en_vdd_cam>;
#vcc_lp = "vif";
status = "okay";
force_bus_start = <CAMERA_I2C_MUX_BUS(0)>;
i2c@0 {
reg = <0>;
i2c-mux,deselect-on-exit;
#size-cells = <0>;
imx378_a@1a {
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
clocks = <&tegra_car TEGRA186_CLK_EXTPERIPH1>,
<&tegra_car TEGRA186_CLK_PLLP_OUT0>;
clock-names = "extperiph1", "pllp_grtba";
mclk = "extperiph1";
reset-gpios = <&tegra_main_gpio CAM0_RST_L GPIO_ACTIVE_HIGH>;
vana-supply = <&en_vdd_cam_hv_2v8>;
vdig-supply = <&en_vdd_cam_1v2>;
status = "okay";
File3: /usr/src/hardware/nvidia/platform/t18x/quill/kernel-dts/quill-modules/tegra186-camera-imx378-c03.dtsi
host1x {
vi@15700000 {
num-channels = <1>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
vi_in0: endpoint {
csi-port = <0>;
bus-width = <2>;
remote-endpoint = <&csi_out0>;
nvcsi@150c0000 {
num-channels = <1>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
csi-port = <0>;
bus-width = <2>;
remote-endpoint = <&imx378_out0>;
port@1 {
reg = <1>;
remote-endpoint = <&vi_in0>;
i2c@3180000 {
tca9548@70 {
i2c@0 {
imx378_a@1a {
devnode = "video0";
compatible = "nvidia,imx378";
reg = <0x1a>;
physical_w = "7.564";
physical_h = "5.476";
sensor_model ="imx378";
dovdd-supply = <&en_vdd_cam>;
avdd-reg = "vana";
dvdd-reg = "vdig";
iovdd-reg = "dovdd";
mode0 { // IMX378_MODE_4056X3040
mclk_khz = "6000";
num_lanes = "2";
phy_mode = "DPHY";
discontinuous_clk = "yes";
cil_settletime = "0";
active_w = "4056";
active_h = "3040";
mode_type = "bayer";
pixel_phase = "rggb";
readout_orientation = "90";
line_length = "4350";
inherent_gain = "1";
mclk_multiplier = "348";
pix_clk_hz = "417600000";
gain_factor = "1000000";
min_gain_val = "1000000";
max_gain_val = "22000000";
min_hdr_ratio = "1";
max_hdr_ratio = "64";
framerate_factor = "1000000";
min_framerate = "1000000";
max_framerate = "30000000";
min_exp_time = "1";
max_exp_time = "65515";
default_exp_time = "3180";/* us */
embedded_metadata_height = "0";
mode1 { // IMX378_MODE_3840X2160
mclk_khz = "6000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "3840";
active_h = "2160";
line_length = "4250";
mclk_multiplier = "238";
pix_clk_hz = "285600000";
min_exp_time = "1";
default_exp_time = "2220";/* us */
mode2 { // IMX378_MODE_1920X1080
mclk_khz = "6000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
line_length = "2240";
mclk_multiplier = "126";
pix_clk_hz = "151200000";
max_framerate = "60000000";
min_exp_time = "1";
default_exp_time = "1105";/* us */
mode3 { // IMX378_MODE_640X480
mclk_khz = "6000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "640";
active_h = "480";
line_length = "1600";
mclk_multiplier = "84";
pix_clk_hz = "100800000";
max_framerate = "120000000";
min_exp_time = "1";
default_exp_time = "505";/* us */
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
imx378_out0: endpoint {
csi-port = <0>;
bus-width = <2>;
remote-endpoint = <&csi_in0>;
lens_imx378_a@3e {
min_focus_distance = "0.0";
hyper_focal = "0.0";
focal_length = "4.52";
f_number = "2.0";
aperture = "2.0";
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <2>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <750000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. "rear" or "front".
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
status = "okay";
badge = "imx378_CH1_396CP";
position = "0";
orientation = "1";
drivernode0 {
status = "okay";
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "imx378 30-001a";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9548@70/i2c@0/imx378_a@1a";
drivernode1 {
pcl_id = "v4l2_lens";
proc-device-tree = "/proc/device-tree/lens_imx378_a@3e/";
