Hi everyone,
I’ve run into failed test problems with the provided SDK samples.
My installation system:
Intel MacBook Pro, NVIDIA 8600M GT 128MB, 2GB RAM, MAC OS X 10.5.2
GCC 4.0.1
This was my first installation of CUDA, so no residual CUDA 1.1 files were lying around.
The steps I followed:
Installed the toolkit (made sure to install the CUDA.kext driver)
Added the environment variables
Installed the SDK
Typed ‘make’ (made sure to not compile to emulation mode)
Result of ./deviceQuery:
There is 1 device supporting CUDA
Device 0: "GeForce 8600M GT"
Major revision number: 1
Minor revision number: 1
Total amount of global memory: 134021120 bytes
Number of multiprocessors: 4
Number of cores: 32
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 0.75 GHz
Concurrent copy and execution: Yes
Test PASSED
From the samples that I have tried, the following run fine:
matrix
matrixMulDrv
Mandelbrot
bitonic
boxFilter
nbody
dxtc
The following fail:
BlackScholes (test fails with overall screen corruption)
MersenneTwister (machine locks up)
alignedTypes (all tests fail)
bandwidthTest (crashes with a bus error)
asyncAPI (nothing happens)
Installing the latest update of Mac OS X from 10.5.2 to 10.5.5 did not improve my results.
Any advice? Could it be related to only having 128MB RAM on the graphics card?
Any help will be greatly appreciated.
