AGX Xavier
• DeepStream Version
5.0
4.5
• TensorRT Version
7.1.3
question
I have a pipeline that runs a segmentation and object detection neural network in parallel. It works well for the first 20 frames but after that I get the following error for every new frame:
ImgAddFences: Couldn’t find a place to store the fences
NVM_LDC : 765, ERR: sAddFences: Failed to add fence to input 0, status:7
NVM_LDC : 1654, ERR: NvMediaLDCAddFences failed. status: 7
VPI_ERROR_INTERNAL: (NVMEDIA_STATUS_ERROR)
In my output I can see that every frame from that moment on is just frame number 20 and I’m not receiving any new frames from my source.
I couldn’t find any information related to this error so I would like to get some advice on the possible scenarios where this error could be thrown so I can get an idea for debugging this issue.
Here is my pipeline:
gst-launch-1.0
gcamsrc fileread=true devid=1234 num_buffers=100 !
capsfilter caps=video/x-raw,format=NV12,width=4000,height=3000 !
tee name=t ! queue !
remap configyaml=./remap-config-left.yml !
‘video/x-raw(memory:NVMM),format=(string)NV12’ !
m.sink_0 nvstreammux name=m batch-size=1 width=4000 height=3000 enable-padding=0 !
nvinfer config-file-path=“./config_infer_primary_yoloV4.txt” !
nvvideoconvert ! nvdsosd ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! mp4mux !
filesink location=“./result_gst_yolo.mp4”
t. ! queue !
n.sink_0 nvstreammux name=n batch-size=1 width=4000 height=3000 enable-padding=0 !
nvinfer config-file-path=“./config_infer_primary_deeplab.txt” !
filesink location="./result_gst_deeplab.mp
