Failed to add stream
I am following this and able to launch the docker-compose. You can see the sudo docker ps result as
When testing the Rest API through POSTMAN It got failed
Even though the API document page, I am getting the same error.
Can anyone help me where I am going wrong? I am using Jetosn Orin Nano.
Seams your ingress config doesn’t work as expect. I see you post this topic: What is the URL and port to see the Deepstream Output on the VLC media player in Jetson platform services?
Please follow this topic to setup ingress config.
@kesong
Again, I did not get where it is mentioned in the document about the ingress configuration.
Today I use the latest NVStreamer and here to my surprise, the things work.
Glad to know it works after use the latest package.
