It works fine, but after a day or two, one of the two cameras starts throwing the Failed to allocate memory error, while the second camera works perfectly fine.
I have tried all the USB ports, and we face the same issue (The camera stopped working after some time).
But after getting the error when I switched the port, the camera started working again.
I have also tried the simple pipeline with Fakesink.
It seems to be memory leak. Pleaser try to run the two cameras in gst-launc-1.0 commands and see if the issue is still present. The command may be like:
Just another suggestion in case the gst-launch-1.10 suggested command still not working. Maybe you should check if the power adapter could be the problem:
