I have a question, the version of DS is 6.0, I must upgrade DS6.1?
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:861 failed to build network since there is no model file matched.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:799 failed to build network.
0:01:35.030324758 14950 0x2261400 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger: NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1934> [UID = 2]: build engine file failed
0:01:35.030379151 14950 0x2261400 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger: NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2020> [UID = 2]: build backend context failed
0:01:35.030404174 14950 0x2261400 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger: NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1257> [UID = 2]: generate backend failed, check config file settings
0:01:35.031215691 14950 0x2261400 WARN nvinfer gstnvinfer.cpp:841:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:01:35.031251382 14950 0x2261400 WARN nvinfer gstnvinfer.cpp:841:gst_nvinfer_start: error: Config file path: config_retinaface.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Hi there @user70013 and welcome to the NVIDIA developer forums!
It is a bit hard to get the context of your question, but judging from the abbreviation and version number you are talking about the DeepStream SDK, correct?
I took the liberty of moving your post to the DeepStream category, I hope that is ok. If not, let me know and I’ll help you find the right place!
Can you help describe the context before hitting this error?
Please also provide complete information as applicable to your setup.
• DeepStream Version
• TensorRT Version
• The pipeline being used
[quote=“yingliu, post:3, topic:226193”]
How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
i have been solve this question,thanks.
i met a new question,the primary sgie, i use retinaface network and the answer is ok, and i use efficientnet in the secondly sgie, the efficientnet model is to classify Face mask, no mask or with mask. the config.txt of The secondary-gie2 as follows:
gpu-id=0
net-scale-factor=1
offsets=77.5;21.2;11.8
model-engine-file=./efficientnet.engine
labelfile-path=./effLabel.txt
force-implicit-batch-dim=1
batch-size=1
0=FP32 and 1=INT8 mode
network-mode=0
#input-object-min-width=64
#input-object-min-height=64
process-mode=2
model-color-format=1
gpu-id=0
gie-unique-id=2
operate-on-gie-id=1
operate-on-class-ids=0
is-classifier=1
output-blob-names=predictions/Softmax
classifier-async-mode=1
classifier-threshold=0.51
process-mode=2
#scaling-filter=0
#scaling-compute-hw=0
but all the face detected in primary sgie after efficientnet model is with mask, the answer is error. how can i solve this questiones, the reference of secondary sgie is deepstream-test2. and my efficientnet model transforms.Normalize([0.485, 0.456, 0.406], [0.229, 0.224, 0.225])
