Hello, yahoo2016:
For compile failure, please take a look at tegra_multimedia_api/README. In jetpack, you need install some components to compile these samples.
For camera_jpeg_capture error, can you run a gst pipeline first to make sure that on-board camera works well? If gst works and camera_jpeg_capture still crashes, please paste syslog as well.
I’ve not seen a “permission fault”. It makes me curious as to whether you are using user “ubuntu” for this test? If not, then try adding your user to group “video”, e.g.:
We can’t run Jetpack on company network. We always got “manifest is broken” error when tried to run Jetpack on different laptops with Ubuntu 14.04. Jetpack on the same laptop runs fine on home network.
Are there ways to install multi-media-api without Jetpack?
nvidia@tegra-ubuntu:~/tegra_multimedia_api/samples/09_camera_jpeg_capture$ ./camera_jpeg_capture
[INFO] (NvEglRenderer.cpp:109) <renderer0> Setting Screen width 640 height 480
initializeDevNode: Failed to open dev node '/dev/camera/video1'; No such file or directory, trying alternate default location
(NvOdmDevice) Error BadParameter: Control 10094858 not found (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function findControlById(), line 1367)
(NvOdmDevice) Error BadParameter: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function getControlRange(), line 299)
initialize: focus query failed
(Argus) Error InvalidState: Scf SensorModeType 0 not found (in src/common/ScfTranslate.cpp, function fromNvMMSensorModeType(), line 322)
PRODUCER: Creating output stream
PRODUCER: Launching consumer thread
CONSUMER: Waiting until producer is connected...
PRODUCER: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
(NvOdmDevice) Error IoctlFailed: (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function allocateBuffers(), line 768)
(NvOdmDevice) Error IoctlFailed: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function enableStreamingConfiguration(), line 1730)
(NvOdmDevice) Error BadParameter: enableStreamingConfiguration FAILED (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorBase.cpp, function writeMode(), line 291)
(NvOdmDevice) Error BadParameter: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function apply(), line 154)
(NvOdmDevice) Error BadParameter: Sensor mode has not been configured! (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function apply(), line 184)
libv4l2: error turning on stream: Invalid argument
(NvOdmDevice) Error IoctlFailed: (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function streamControl(), line 1163)
(NvOdmDevice) Error IoctlFailed: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function apply(), line 186)
SCF: Error Timeout: (propagating from src/services/autocontrol/NvCameraIspDriver.cpp, function programIsp(), line 1199)
SCF: Error Timeout: (propagating from src/services/autocontrol/NvCameraIspDriver.cpp, function programIsp(), line 1241)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceCore.cpp, function programIsp(), line 321)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceCore.cpp, function doCSItoISPCapture(), line 446)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceCore.cpp, function issueCapture(), line 344)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1190)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1042)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
launchCC abort cc 104
SCF: Error Timeout: (propagating from src/api/Session.cpp, function capture(), line 750)
(Argus) Error Timeout: Failed to submit first capture request (propagating from src/api/CaptureSessionImpl.cpp, function submitCaptureRequests(), line 301)
(Argus) Error Timeout: (propagating from src/api/CaptureSessionImpl.cpp, function threadFunction(), line 741)
SCF: Error Timeout: ISP port 0 timed out! (in src/services/capture/CaptureServiceDeviceIsp.cpp, function waitIspFrameEnd(), line 663)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceDeviceIsp.cpp, function waitIspFrameEnd(), line 704)
SCF: Error Timeout: (propagating from src/common/Utils.cpp, function workerThread(), line 113)
SCF: Error Timeout: Worker thread IspHw frameComplete failed (in src/common/Utils.cpp, function workerThread(), line 130)
Error: waitCsiFrameStart timeout guid 0
VI Stream Id = 2 Virtual Channel = 0
************VI Debug Registers**********
VI_CSIMUX_STAT_FRAME_8 = 0x00000000
VI_CSIMUX_FRAME_STATUS_0 = 0x00000000
VI_CFG_INTERRUPT_STATUS_0 = 0x3f000000
VI_ISPBUFA_ERROR_0 = 0x00000000
VI_FMLITE_ERROR_0 = 0x00000000
VI_NOTIFY_ERROR_0 = 0x00000000
CSI Stream Id = 2 Brick Id = 1
************CSI Debug Registers**********
NVCSI_PHY_0_CILA_INTR_STATUS_CILA_0 = 0x00000000
NVCSI_PHY_0_CILB_INTR_STATUS_CILB_0 = 0x00000000
NVCSI_STREAM_0_INTR_STATUS_0 = 0x00000000
NVCSI_STREAM_0_ERR_INTR_STATUS_0 = 0x00000000
NVCSI_STREAM_0_ERROR_STATUS2VI_VC0_0 = 0x9f80bf00
NVCSI_STREAM_0_ERROR_STATUS2VI_VC1_0 = 0x00000000
NVCSI_STREAM_0_ERROR_STATUS2VI_VC2_0 = 0x00000000
NVCSI_STREAM_0_ERROR_STATUS2VI_VC3_0 = 0x00000000
Error: waitCsiFrameStart Something went wrong with waiting on frame start
SCF: Error Timeout: ISP Stats timed out! (in src/services/capture/CaptureServiceDeviceIsp.cpp, function waitIspStatsFinished(), line 746)
How to solve it? Could you give me some suggestions? Thank you in advance!
Hi,jachen,
First,thank for your suggestion.I have checked on-board as your said.I run the code on jstson-tx2 terminal.
gst-launch-1.0 nvcamerasrc ! nvoverlaysink
Work well.
Then,i run the under code.
Could you give me some suggestions?Thank you in advance.
Another possible reason is that the platform is not flashed correctly.
please remove all packages in jetpack directory, and re-run jetpack, re-flash the device and check whether it can work.
