Failed to build TensorRT engine
Description
A clear and concise description of the bug or issue.
Environment
TensorRT Version: 8.6.1.6
GPU Type: RTX 4070 Laptop
Nvidia Driver Version: 572.47
CUDA Version: 11.8
CUDNN Version: 8.7
Operating System + Version: Window 10
Python Version (if applicable): 3.10
TensorFlow Version (if applicable): I don’t know
PyTorch Version (if applicable): I don’t know
Baremetal or Container (if container which image + tag): I don’t know
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
  • Exact steps/commands to build your repro
  • Exact steps/commands to run your repro
  • Full traceback of errors encountered
I run Omniverse Audio2Face, but I get an error.
The execution environment is Windows 10.
Does it not run on the windows 10?
Could you take a look at the attached image and log?
2025-02-24 00:31:44 [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated key:‘P (On Press)’
2025-02-24 00:31:44 [Warning] [omni.kit.hotkeys.core.registry] – Global [omni.kit.menu.utils] omni.kit.menu.edit::parent_prims.P
2025-02-24 00:31:44 [Warning] [omni.kit.hotkeys.core.registry] – Global [omni.audio2face.wizard-105.9.0] omni.audio2face.wizard-105.9.0::audio2face__player__play_pause.P
2025-02-24 00:31:44 [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.menu.utils] omni.kit.menu.edit::parent_prims.P, error code: Duplicated key definition
2025-02-24 00:31:44 [Warning] [omni.usd] Warning (secondary thread): in _ReportErrors at line 2890 of W:\ac88d7d902b57417\USD\pxr\usd\usd\stage.cpp – Could not load sublayer @metrics:UnitsAdjust-160680d357780c2b3e46f33c2c8dc7d3.metricsAssembler@ of layer @C:/users/teddy/appdata/local/ov/pkg/audio2face-2023.2.0/exts/omni.audio2face.wizard/deps/audio2face-assets/mark/mesh/mark_fullface_model.usd@; skipping. (instantiating stage on stage @C:/users/teddy/appdata/local/ov/pkg/audio2face-2023.2.0/exts/omni.audio2face.wizard/assets/demo_fullface_mark.usda@ <0000021BDAC32B10>)
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] Unable to build TensorRT network for: c:\users\teddy\appdata\local\ov\pkg\audio2face-2023.2.0\exts\omni.audio2face.core_deps\deps\audio2face-nets\nets_fullface\mark_v2\network.onnx
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] Async Task Failed: <Task finished name=‘Task-286’ coro=<A2FCoreFullfaceInstance._init_network_name_async() done, defined at c:/users/teddy/appdata/local/ov/pkg/audio2face-2023.2.0/exts/omni.audio2face.core/omni/audio2face/core/scripts/instance_fullface.py:614> exception=RuntimeError(“Error during running command: [‘c:\\users\\teddy\\appdata\\local\\ov\\pkg\\audio2face-2023.2.0\\exts\\omni.audio2face.inference_deps\\deps\\audio2face-inference-deps\\bin\\trtexec.exe’, ‘–onnx=c:\\users\\teddy\\appdata\\local\\ov\\pkg\\audio2face-2023.2.0\\exts\\omni.audio2face.core_deps\\deps\\audio2face-nets\\nets_fullface\\mark_v2\\network.onnx’, ‘–saveEngine=C:\\Users\\Teddy\\AppData\\Local\\ov\\cache\\Kit\\105.1\\c677816d\\audio2face-nets\\mark_v2\\network_device0_fp32.trt’, ‘–device=0’, ‘–tacticSources=-CUDNN’, ‘–explicitBatch’]”)>
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] Error: Error during running command: [‘c:\users\teddy\appdata\local\ov\pkg\audio2face-2023.2.0\exts\omni.audio2face.inference_deps\deps\audio2face-inference-deps\bin\trtexec.exe’, ‘–onnx=c:\users\teddy\appdata\local\ov\pkg\audio2face-2023.2.0\exts\omni.audio2face.core_deps\deps\audio2face-nets\nets_fullface\mark_v2\network.onnx’, ‘–saveEngine=C:\Users\Teddy\AppData\Local\ov\cache\Kit\105.1\c677816d\audio2face-nets\mark_v2\network_device0_fp32.trt’, ‘–device=0’, ‘–tacticSources=-CUDNN’, ‘–explicitBatch’]
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] Traceback (most recent call last):
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] File “c:/users/teddy/appdata/local/ov/pkg/audio2face-2023.2.0/exts/omni.audio2face.utility/omni/audio2face/utility/scripts/utils.py”, line 134, in _done_callback
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] task.result()
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] File “c:/users/teddy/appdata/local/ov/pkg/audio2face-2023.2.0/exts/omni.audio2face.core/omni/audio2face/core/scripts/instance_fullface.py”, line 616, in _init_network_name_async
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] await self._processor.set_network(network_fpath, network_name)
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] File “c:/users/teddy/appdata/local/ov/pkg/audio2face-2023.2.0/exts/omni.audio2face.core/omni/audio2face/core/scripts/processor_base.py”, line 137, in set_network
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] await self._build_and_load_a2f_network(
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] File “c:/users/teddy/appdata/local/ov/pkg/audio2face-2023.2.0/exts/omni.audio2face.core/omni/audio2face/core/scripts/processor_fullface.py”, line 354, in _build_and_load_a2f_network
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] await self._trt_builder.prepare_and_load_trt_network(
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] File “c:/users/teddy/appdata/local/ov/pkg/audio2face-2023.2.0/exts/omni.audio2face.utility/omni/audio2face/utility/scripts/utils.py”, line 55, in wrapper
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] return await func(*args, **kwargs)
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] File “c:/users/teddy/appdata/local/ov/pkg/audio2face-2023.2.0/exts/omni.audio2face.inference/omni/audio2face/inference/scripts/trt_builder.py”, line 54, in prepare_and_load_trt_network
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] await self._build_or_rebuild_and_load_trt_network(
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] File “c:/users/teddy/appdata/local/ov/pkg/audio2face-2023.2.0/exts/omni.audio2face.inference/omni/audio2face/inference/scripts/trt_builder.py”, line 77, in _build_or_rebuild_and_load_trt_network
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] await self._build_and_load_trt_network(
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] File “c:/users/teddy/appdata/local/ov/pkg/audio2face-2023.2.0/exts/omni.audio2face.inference/omni/audio2face/inference/scripts/trt_builder.py”, line 87, in _build_and_load_trt_network
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] await self._build_trt_network(input_network_fpath, trt_network_fpath, optimizer_params)
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] File “c:/users/teddy/appdata/local/ov/pkg/audio2face-2023.2.0/exts/omni.audio2face.inference/omni/audio2face/inference/scripts/trt_builder.py”, line 116, in _build_trt_network
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] await run_cmd(cmd, cmd_name=“TRTEXEC”, progress_fn=self._build_trt_network_progress)
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] File “c:/users/teddy/appdata/local/ov/pkg/audio2face-2023.2.0/exts/omni.audio2face.utility/omni/audio2face/utility/scripts/cmd_runner.py”, line 76, in run_cmd_in_app
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] await run_cmd(cmd, cmd_name, progress)
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] File “c:/users/teddy/appdata/local/ov/pkg/audio2face-2023.2.0/exts/omni.audio2face.utility/omni/audio2face/utility/scripts/cmd_runner.py”, line 62, in run_cmd
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] raise RuntimeError(“Error during running command: {}”.format(cmd))
2025-02-24 00:31:46 [Error] [omni.audio2face.utility.scripts.utils] RuntimeError: Error during running command: [‘c:\users\teddy\appdata\local\ov\pkg\audio2face-2023.2.0\exts\omni.audio2face.inference_deps\deps\audio2face-inference-deps\bin\trtexec.exe’, ‘–onnx=c:\users\teddy\appdata\local\ov\pkg\audio2face-2023.2.0\exts\omni.audio2face.core_deps\deps\audio2face-nets\nets_fullface\mark_v2\network.onnx’, ‘–saveEngine=C:\Users\Teddy\AppData\Local\ov\cache\Kit\105.1\c677816d\audio2face-nets\mark_v2\network_device0_fp32.trt’, ‘–device=0’, ‘–tacticSources=-CUDNN’, ‘–explicitBatch’]
kit_20250224_092827.log (1009.6 KB)
Hi @ps.kang159 ,
Moving this to Omniverse Forum
