When I tried to compile and build yocto OS image for Jetson nano board with machine name “jetson-nano-qspi-sd” as given in doc (Yocto Support for NVIDIA Jetson Platforms - Setting up Yocto].
Getting below error:
ERROR: OE-core’s config sanity checker detected a potential misconfiguration.
Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
Following is the list of potential problems / advisories:
MACHINE=jetson-nano-qspi-sd is invalid. Please set a valid MACHINE in your local.conf, environment or other configuration file.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
Please guide me about what will be the valid MACHINE NAME for building yocto OS for jetson nano board.
