Failed to compile Cuda on jetson TX2
Blockquote
20:04:03 INFO: CUDA Cross Compile Package on Host - host: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.5.1/JETPACK_451_b17/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb to /media/jetsonhostpc/841a9ca5-d24b-49de-8e73-d245a962e433/home/nanohostpc/Downloads/sdkmanager_from_jetsonhostpc/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb
20:14:47 INFO: CUDA Cross Compile Package on Host - host: verifying checksum of /media/jetsonhostpc/841a9ca5-d24b-49de-8e73-d245a962e433/home/nanohostpc/Downloads/sdkmanager_from_jetsonhostpc/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb
20:14:53 INFO: CUDA Cross Compile Package on Host - host: download /media/jetsonhostpc/841a9ca5-d24b-49de-8e73-d245a962e433/home/nanohostpc/Downloads/sdkmanager_from_jetsonhostpc/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb successfully, checksum is correct
20:28:43 DEBUG: CUDA Cross Compile Package on Host - host: using adapter to install NV_CUDA_CROSS_HOST_COMP@host to /media/jetsonhostpc/841a9ca5-d24b-49de-8e73-d245a962e433/home/nanohostpc/Downloads/sdkmanager_from_jetsonhostpc/data/JetPack_4.5.1_Linux
20:28:43 INFO: CUDA Cross Compile Package on Host - host: [host] [ Disk Avail:22.59 GB ]
20:28:43 INFO: CUDA Cross Compile Package on Host - host: Installing component ‘CUDA Cross Compile Package on Host’ (NV_CUDA_CROSS_HOST_COMP)
20:28:43 INFO: CUDA Cross Compile Package on Host - host: NV_CUDA_CROSS_HOST_COMP include 1 package
20:28:43 INFO: CUDA Cross Compile Package on Host - host: [ Package Install Started ]
20:28:43 INFO: CUDA Cross Compile Package on Host - host: deb installer start to install
20:28:43 INFO: CUDA Cross Compile Package on Host - host: exec_command: dpkg -f /media/jetsonhostpc/841a9ca5-d24b-49de-8e73-d245a962e433/home/nanohostpc/Downloads/sdkmanager_from_jetsonhostpc/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb Package | tr -d ‘\n’
20:28:43 INFO: CUDA Cross Compile Package on Host - host: exec_command: dpkg -f /media/jetsonhostpc/841a9ca5-d24b-49de-8e73-d245a962e433/home/nanohostpc/Downloads/sdkmanager_from_jetsonhostpc/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb Version | tr -d ‘\n’
20:28:43 INFO: CUDA Cross Compile Package on Host - host: deb file /media/jetsonhostpc/841a9ca5-d24b-49de-8e73-d245a962e433/home/nanohostpc/Downloads/sdkmanager_from_jetsonhostpc/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb, package name [dpkg-deb: error: failed to read archive ‘/media/jetsonhostpc/841a9ca5-d24b-49de-8e73-d245a962e433/home/nanohostpc/Downloads/sdkmanager_from_jetsonhostpc/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb’: No such file or directory
20:28:43 INFO: CUDA Cross Compile Package on Host - host: ], package version [dpkg-deb: error: failed to read archive ‘/media/jetsonhostpc/841a9ca5-d24b-49de-8e73-d245a962e433/home/nanohostpc/Downloads/sdkmanager_from_jetsonhostpc/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb’: No such file or directory
20:28:43 INFO: CUDA Cross Compile Package on Host - host: infer package info from file name cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb [ name: cuda-repo-cross-aarch64-10-2-local-10.2.89, version: 1.0-1 ]
20:28:43 ERROR: CUDA Cross Compile Package on Host - host: invalid package info inferred from file name: {cuda-repo-cross-aarch64-10-2-local-10.2.89 1.0-1}; [deb_path]: /media/jetsonhostpc/841a9ca5-d24b-49de-8e73-d245a962e433/home/nanohostpc/Downloads/sdkmanager_from_jetsonhostpc/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb
20:28:43 INFO: CUDA Cross Compile Package on Host - host: exec_command: sudo -E apt-get install -y --allow-downgrades ‘/media/jetsonhostpc/841a9ca5-d24b-49de-8e73-d245a962e433/home/nanohostpc/Downloads/sdkmanager_from_jetsonhostpc/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb’
20:28:43 INFO: CUDA Cross Compile Package on Host - host: Reading package lists…
20:28:43 ERROR: CUDA Cross Compile Package on Host - host: E: Unsupported file /media/jetsonhostpc/841a9ca5-d24b-49de-8e73-d245a962e433/home/nanohostpc/Downloads/sdkmanager_from_jetsonhostpc/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb given on commandline
20:28:43 INFO: CUDA Cross Compile Package on Host - host: exec_command: sudo apt-get check
20:28:43 INFO: CUDA Cross Compile Package on Host - host: Building dependency tree…
20:28:43 INFO: CUDA Cross Compile Package on Host - host: Reading state information…
20:28:43 INFO: CUDA Cross Compile Package on Host - host: no repoPackageInfo found in additionalParameters.
20:28:43 INFO: CUDA Cross Compile Package on Host - host: exec_command: dpkg -L cuda-repo-cross-aarch64-10-2-local-10.2.89 | grep ‘.pub$’ | tr -d ‘\n’
20:28:43 INFO: CUDA Cross Compile Package on Host - host: [ Package Install Finished with Error ]
20:28:43 INFO: CUDA Cross Compile Package on Host - host: [host] [ 8.00 KB used. Disk Avail: 22.59 GB ]
20:28:43 INFO: CUDA Cross Compile Package on Host - host: [ NV_CUDA_CROSS_HOST_COMP Install took 1s ]
20:28:43 ERROR: CUDA Cross Compile Package on Host - host: [error]: key file [dpkg-query: package ‘cuda-repo-cross-aarch64-10-2-local-10.2.89’ is not installed
20:28:43 INFO: CUDA Cross Compile Package on Host - host: Use dpkg --info (= dpkg-deb --info) to examine archive files,
20:28:43 INFO: CUDA Cross Compile Package on Host - host: and dpkg --contents (= dpkg-deb --contents) to list their contents.
20:28:43 INFO: CUDA Cross Compile Package on Host - host: ] not found; [error]: stat dpkg-query: package ‘cuda-repo-cross-aarch64-10-2-local-10.2.89’ is not installed
20:28:43 INFO: CUDA Cross Compile Package on Host - host: : no such file or directory; [deb_path]: /media/jetsonhostpc/841a9ca5-d24b-49de-8e73-d245a962e433/home/nanohostpc/Downloads/sdkmanager_from_jetsonhostpc/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb
20:28:43 ERROR: CUDA Cross Compile Package on Host - host: command terminated with error
20:28:43 SUMMARY: CUDA Cross Compile Package on Host - host: First Error: Failed to run apt-key add command [host]
Can you tell me how to resolve this errors?
Thank you.
Can you tell me how to resolve this install errors?
Thank you,
Are you trying to install those SDKs again to meet this issue? OR this is the first trial?
Please provide the ~/.nvsdkm/sdkm.log
Hello
sdkm-2021-05-28-20-01-17.log (1.9 MB)
Thank you.
Hi Hodu,
Seems that the file was downloaded to a mounted disk, however, the mounted disk got lost during installation? Can you please check what’s the output of ls -al /media/jetsonhostpc/841a9ca5-d24b-49de-8e73-d245a962e433/home/nanohostpc/Downloads/sdkmanager_from_jetsonhostpc/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb command?
jetsonhostpc@jetsonhostpc-Vostro-470:/media/jetsonhostpc/841a9ca5-d24b-49de-8e73-d245a962e433/home/nanohostpc/Downloads/sdkmanager_from_jetsonhostpc$ ls -al cuda-repo-
cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb cuda-repo-ubuntu1804-10-2-local-10.2.89-440.40_1.0-1_amd64.deb
i can’t find cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb
Thank you.
Hi Hodu,
From the log, the cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb file has been downloaded successfully, with correct checksum. Do you have any idea what may cause it removed?
I never deleted it myself.
I just clicked the next button as instructed by the sdk manager.
Thank you.
Hello Hodu,
SDK Manager doesn’t delete downloaded files either.
Please check if this is hardware issue or other issue.
I’m re-trying to install components.
Thank you,m
Hi Hodu,
After reinstalling components do you see cuda ?
