I’m trying to connect a Baslet USB3 camera to the tx2.
The camera is being recognised by PylonViewer as a Usb camera (in the drop down menu, with the correct name) but when double clicking it to run it, I get the following error:
“Failed to load embedded nodemap UsbStreamParams”
The camera, when connected to a laptop works - so it’s not the camera / cable.
Thanks DaneLLL
the camera is not added as /dev/video1 - so I assume it’s impossible?
Are you aware of any external drivers or something I could install to run it?
