Hi all,
After installing DriveInstall 4.1.6, I failed to connect GSML camera. I updated AURIX firmware to 2.01.03 as suggested. Here is what I got:
nvidia@nvidia:/usr/local/driveworks/bin$ ./sample_camera_gmsl --camera-type=ar0231-rccb
Program Arguments:
--csi-port=ab
--fifo-size=3
--offscreen=0
--serialize-bitrate=8000000
--serialize-framerate=30
--serialize-type=h264
--slave=0
--write-file=
Initialize DriveWorks SDK v0.3.400
Release build with GNU 4.9.2 from v0.3.0-rc8-0-g3eeebea against PDK v4.1.6.1
SDK: Resources mounted from /usr/local/driveworks-0.3/data/resources
SDK: Create NvMediaDevice
SDK: use EGL display as provided
SDK: dGPU has been detected as device number 0
SDK: iGPU has been detected as device number 1
SDK: Default GPU Device set to device number 0
SAL: identified board as DrivePX2-TegraA
SensorFactory::createSensor() -> camera.gmsl, camera-type=ar0231-rccb,csi-port=ab,fifo-size=3,offscreen=0,serialize-bitrate=8000000,serialize-framerate=30,serialize-type=h264,slave=0,write-file=,output-format=yuv
CameraGMSL: required FPS = 30, resolution = 1920x1208
***** aurix state *****
CAM_PWR_ON: 0x0
TEGRA_GMSL: TEGRA B
TEGRA_FPDL: TEGRA B
TEGRA_A_HDMI: MXM
TEGRA_B_HDMI: MXM
TEGRA_PCI: TEGRA B
FAN_STATE: UNKNOWN
CAM_PWR_ON: 0x1
TEGRA_GMSL: UNKNOWN
TEGRA_FPDL: UNKNOWN
TEGRA_A_HDMI: UNKNOWN
TEGRA_B_HDMI: UNKNOWN
TEGRA_PCI: UNKNOWN
FAN_STATE: UNKNOWN
Camera image with 1920x1208 at 30 FPS
[IppIscComponentParseEmbeddedData:350] Failed to parse embedded data
[UpdateIppInfo:168] Failed to parse embedded data
[ICPThreadFunc:450] Failed with internal failure error
CameraGMSL: Internal failure
ERROR readFrame: DW_NOT_READY
^C
CAM_PWR_ON: 0x0
TEGRA_GMSL: UNKNOWN
TEGRA_FPDL: UNKNOWN
TEGRA_PCI: UNKNOWN
FAN_STATE: UNKNOWN
SDK: Release NvMediaDevice
Driveworks SDK released
I also tried applying patch titled 4.1.2.0 Vibrante 4.1 Linux Drive PX 2 - PDK and SDK Patch - Bug 1854366. I had to use this patch when I was using old PDK 4.1.2. But didn’t help in this version, so I converted back to original version of patched library file.
