I have recently installed AODT(version : 1.4.0) on my ubuntu 24 system with RTX 5090 GPU. Following the installation section of the documentation, need to authenticate before loading the tokyo.usd project so opened the localhost:8080 and entered credentials to open omniververse server then got error for failed to connect to server.
I have attached the required snapshots for clarity of the issue.
Please support or guide on this.
Thank you
Are you able to access these from a browser?
http://localhost:8080/
http://localhost:3180/
If not, replace localhost with the IP address and try. Let us know what you see.
Thankyou for the response.
yes, I am able to access these ports and have authenticated with the credentials given in the docs.
I was facing this authentication issue earlier but now it got resolved, there is another issue coming in attaching the worker by clicking on the gear icon but it says no worker found.
Please guide on attaching the worker so that i can load the tokyo.usd map example and proceed further.
Any suggestion on how to attach worker as i am getting no available worker error?
@prasad.aalekh
We have released AODT version 1.5.0 (1.5.1 is imminent). The workflows are diffrent and much simpler than 1.4.1. Please update to 1.5.0
