Ubuntu 19.10 (5.3 kernel), P100 12GB card
| NVIDIA-SMI 440.56 Driver Version: 440.56 CUDA Version: 10.2 |
| 0 GRID P100C-1Q On | 00000000:00:0A.0 Off | 0 |
| N/A N/A P0 N/A / N/A | 255MiB / 1024MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 722 G /usr/lib/xorg/Xorg 162MiB |
When I run simple CUDA test (./EGLStream_CUDA_Interop) it throws an error:
Found 1 cuda devices
Found EGL-CUDA Capable device with CUDA Device id = 0
Created EGLStream 0x56399ab0c291
EGLStream initialized
CUDA Producer on GPU Device 0: "GRID P100C-1Q" with compute capability 6.0
failed to create CUDA context (0x3E7)
&&&& EGLStream interop test FAILED
According to strace, the only library that was not found is libnvtegra.so but AFAIK it doesn’t matter.
