I have similar error, need someone’s help! Thanks
Continuing the discussion from Failed to create Hydra Engine - Omniverse Code:
kit_20230717_160302.log (1.3 MB)
Hi @lily.chen - The error message “Failed to create Hydra Engine” typically indicates an issue with the graphics rendering engine. The flag you’re using (--/renderer/multiGpu/enabled=false
) is intended to disable multi-GPU rendering, which can sometimes resolve issues if your system is having trouble managing multiple GPUs.
Here are a few things you can try to resolve this issue:
