Failed to create 'primary_gie' | DeepStream6.1.1 on Azure
• Hardware Platform (Azure Linux VM | 22.04)
• DeepStream Version 6.1.1
• JetPack Version (valid for Jetson only) NA
• TensorRT Version 8.4.1.5
| NVIDIA-SMI 525.60.13    Driver Version: 525.60.13    CUDA Version: 12.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  Tesla T4            On   | 00000001:00:00.0 Off |                    0 |
| N/A   31C    P8    12W /  70W |      2MiB / 15360MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
Installation procedure : Quickstart Guide — DeepStream 6.1.1 Release documentation
Running sample apps fails with error:
$ sudo deepstream-app -c source2_1080p_dec_infer-resnet_demux_int8.txt
** ERROR: <create_primary_gie_bin:120>: Failed to create 'primary_gie'
** ERROR: <create_primary_gie_bin:185>: create_primary_gie_bin failed
** ERROR: <create_pipeline:1327>: create_pipeline failed
** ERROR: <main:697>: Failed to create pipeline
Quitting
App run failed
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one.
The driver version and CUDA version are all wrong. Please follow the compatibility: Quickstart Guide — DeepStream 6.1.1 Release documentation
