Hey guys. I try to build a benchmark on DOCA SDK and implement it mostly based on the provided samples dma_copy_host
and dma_copy_dpu
. However, I found a problem that when I try to use more than 4 threads in benchmark, the function doca_ctx_workq_add
will throw an error showing DMA work queue context unable to create QP. err=DOCA_ERROR_NO_MEMORY
. However, when I use configuration like 4 clients and 2 threads each, the benchmark will not throw the error. It’s quite strange, so I’m writing for a help.
You can find my benchmark on github and I have checked that the DPU can create more than 4 QPs under a normal RDMA benchmark so I guess that the DPU works well.
Also, here’s the output of ulimit -a
on my DPU.
core file size (blocks, -c) 0
data seg size (kbytes, -d) unlimited
scheduling priority (-e) 0
file size (blocks, -f) unlimited
pending signals (-i) 63594
max locked memory (kbytes, -l) unlimited
max memory size (kbytes, -m) unlimited
open files (-n) 1024
pipe size (512 bytes, -p) 8
POSIX message queues (bytes, -q) 819200
real-time priority (-r) 0
stack size (kbytes, -s) 8192
cpu time (seconds, -t) unlimited
max user processes (-u) 63594
virtual memory (kbytes, -v) unlimited
file locks (-x) unlimited```
