Deepstream docker nvcr.io/nvidia/deepstream:7.1-triton-multiarch is used to run deepstream_parallel_inference_app.
I can run and display images using deepstream-test1 successfully in the docker.
But for running deepstream_parallel_inference_app, I have the following errors as Failed to create 'sink_sub_bin_encoder1'
Full messages are as follow. How can I solver the issue?
root@user-Nuvo-10000-Series:/workspace/opt/nvidia/deepstream/deepstream-7.1/sources/apps/sample_apps/deepstream_reference_apps/deepstream_parallel_inference_app/tritonclient/sample# ./apps/deepstream-parallel-infer/deepstream-parallel-infer -c configs/apps/bodypose_yolo_lpr/source4_1080p_dec_parallel_infer.yml
src_ids:0;1;2
Unknown key enable-batch-process for tracker
Unknown key enable-past-frame for tracker
src_ids:1;2;3
src_ids:1;2;3
NVDSMETAMUX_CFG_PARSER: Group 'user-configs' ignored
Unknown or legacy key specified 'is-classifier' for group [property]
i:0, src_id_num:3
link_streamdemux_to_streammux, srid:0, mux:0
link_streamdemux_to_streammux, srid:1, mux:0
link_streamdemux_to_streammux, srid:2, mux:0
** INFO: <create_primary_gie_bin:147>: gpu-id: 0 in primary-gie group is ignored, only accept in nvinferserver's config
i:1, src_id_num:3
link_streamdemux_to_streammux, srid:1, mux:1
link_streamdemux_to_streammux, srid:2, mux:1
link_streamdemux_to_streammux, srid:3, mux:1
i:2, src_id_num:3
link_streamdemux_to_streammux, srid:1, mux:2
link_streamdemux_to_streammux, srid:2, mux:2
link_streamdemux_to_streammux, srid:3, mux:2
** ERROR: <create_encode_file_bin:393>: Failed to create 'sink_sub_bin_encoder1'
** ERROR: <create_encode_file_bin:520>: create_encode_file_bin failed
** ERROR: <create_sink_bin:869>: create_sink_bin failed
creating sink bin failed
Quitting
App run successful
gst-inspect-1.0 nvv4l2h264enc produced the following messages.
root@user-Nuvo-10000-Series:/workspace/opt/nvidia/deepstream/deepstream-7.1/sources/apps/sample_apps/deepstream_reference_apps/deepstream_parallel_inference_app/tritonclient/sample# gst-inspect-1.0 nvv4l2h264enc
(gst-plugin-scanner:60): GStreamer-WARNING **: 08:31:21.469: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstsndfile.so': libFLAC.so.8: cannot open shared object file: No such file or directory
(gst-plugin-scanner:60): GStreamer-WARNING **: 08:31:21.470: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmplex.so': libmjpegutils-2.1.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:62): GStreamer-WARNING **: 08:31:21.528: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstpulseaudio.so': libFLAC.so.8: cannot open shared object file: No such file or directory
(gst-plugin-scanner:62): GStreamer-WARNING **: 08:31:21.534: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpg123.so': libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:62): GStreamer-WARNING **: 08:31:21.538: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstchromaprint.so': libavcodec.so.58: cannot open shared object file: No such file or directory
(gst-plugin-scanner:62): GStreamer-WARNING **: 08:31:21.551: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstlame.so': libmp3lame.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:62): GStreamer-WARNING **: 08:31:21.553: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstfluidsynthmidi.so': libFLAC.so.8: cannot open shared object file: No such file or directory
(gst-plugin-scanner:62): GStreamer-WARNING **: 08:31:21.598: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:62): GStreamer-WARNING **: 08:31:21.608: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopenmpt.so': libmpg123.so.0: cannot open shared object file: No such file or directory
Factory Details:
Rank primary + 1 (257)
Long-name V4L2 H.264 Encoder
Klass Codec/Encoder/Video
Description Encode H.264 video streams via V4L2 API
Author ayaka <ayaka@soulik.info>
Plugin Details:
Name nvvideo4linux2
Description Nvidia elements for Video 4 Linux
Filename /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideo4linux2.so
Version 1.14.0
License LGPL
Source module nvvideo4linux2
Binary package nvvideo4linux2
Origin URL http://nvidia.com/
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstVideoEncoder
+----GstV4l2VideoEnc
+----GstV4l2H264Enc
+----nvv4l2h264enc
Implemented Interfaces:
GstPreset
Pad Templates:
SINK template: 'sink'
Availability: Always
Capabilities:
video/x-raw(memory:NVMM)
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
format: { (string)I420, (string)NV12, (string)P010_10LE, (string)Y444, (string)Y444_10LE, (string)NV24 }
framerate: [ 0/1, 2147483647/1 ]
SRC template: 'src'
Capabilities:
video/x-h264
stream-format: byte-stream
alignment: { (string)au, (string)nal }
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
SINK: 'sink'
Pad Template: 'sink'
SRC: 'src'
Pad Template: 'src'
